Built 1998 Trans Am
Built 1998 Trans Am
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $11000
Mileage: 168000
Private or Dealer Listing: Private Listing
Location (State): RI
Color: Orange
Drivetrain: Rear Wheel Drive
LQ4 6.0 block .005 over, balanced and blueprinted.
05 LS2 crank polished and balanced.
Mahle flat top pistons with valve reliefs.
Scat rods, arp bolts. Cleavite bearings.
Procomp heads, with Ferrara valves, .650 dual springs, 850 hydraulic roller lifters, comp cams 7.4 pushrods, comp cams lsxr 113LSA cam.
Fast 102 lsxr intake, billet fuel rails, 36lb injectors. Procomp 102 tb, NOS wet plate. All less than 500 miles.
EXHAUST
full SLP stainless 1-7/8 headers (emissions blocked off) 3" slp loudmouth with 4" dual tips
Transmission
4L60E rebuilt by Trans specialties 3200 circle d converter (500 miles)
Rebuilt 10 bolt with 3.73 gears
SUSPENSION
FAYS2 watts link
Founders performance roto/poly LCA.
BMR upper and lower adjustable A-arms. New KYB strut mounts, Bilstein front shocks with BMR 550 lb front springs. HP tokico blues in rear with eibach 140 progressive springs.
BRAKES
C5 conversion with BMR brackets.
Stainless steel lines, drilled and slotted rotors
MISC..
Dual core aluminum radiator with custom 5 electric cooling fan setup.
Oil cooler. Transmission cooler.
255LPH WALBRO fuel pump with hot wire kit.
Kenwood stereo with dead space 10" sub box, and 1500 watt amp.
Poly motor, tranny, and sway bar links.
WHEELS
C4 17x9 chrome with sumitommo tires 275/40/17 (fairly new)
BODY
Sunset orange metallic paint, 4 years old. Firehawk raptor hood with functional ram air scoops. Badge delete. HID 8000k fog lights. Dent on rear quarter, and tire mark on door. Paint cracked and peeled away on lower front right facia. Body gas 168,000 miles on it. I'm sure I'm forgetting a few things. Preferred contact through texts at 401-255-2966
Don't be afraid of the miles on this car it looks like it is brand new I seen it in person this car is also real fast and done up right . I think it is one of the best looking TA around. If I didn"t have so many car I would buy it is a STEAL for $10,000
