FS: 2004 PBM GTO, M6, Engine/Susp./etc mods.
This car is a blast to drive and always leaves a SEG.
Perusing the list below you'll find that this GTO has nearly all mods a guy could want or need; it's a far more well rounded car than the majority on the forums, having all the necessary stop, turn, and go mods to make it a safe, reliable, and fun street bruiser. I'd say it's one of the classiest looking GTOs, too, with just enough flash to be eye-catching, but none of the tacky spoilers, stickers, and what-not that make these cars look "rice". You'll also see that I've got a few extra parts waiting to be installed, so you can decide if you want to finish the work or sell 'em off for a little $$$.
Regarding the modifications, the engine work was done by RevXtreme in '04 and tuned by Jeremy Formato/FasterPROMs; previously dyno'd at 430/390 with that "little" camshaft. Gears installed by SpeedInc. Instrument cluster and radio modifications by White Auto Media, while I did the other interior color changes in-house w/ help of an electrical engineer from work. I also have modified the AeroForce gauges with custom billet bezels and plain black faces. Suspension and brake work also done in-house. Spoiler delete was done "the right way", with the holes filled and painted. There may be other minor modifications that I forgot to list; I'm sure I have all the major ones.
Price? $20000. I am able to deliver (trailer) the car to one of the surrounding states, if needed, or pick someone up at the DSM or CID airports.
Photos: Multiple LARGER photos available on my Picasa Album (http://picasaweb.google.com/itslow/GTO).
Willing to pay a finders fee if you can find me a buyer that completes the sale.
2004 GTO, Phantom Black/Black, 6 speed, ~17,600 miles (as of 22JUL09)
To Be Installed (eventually):
Take-Off/Extra Parts:
- AFR 205cc Heads, Angle Milled to 11:1
- Comp Cams 224/228-113 .581"/.588"
- Comp Cams 918 Valve Springs
- Comp Cams Ti Retainers
- Comp Cams 7.400" Pushrods
- Comp Cams Double Roller Timing Chain
- LS6 Oil Pump
- SLP 160-deg T-stat
- FAST 78mm Throttle Body
- ASP Underdrive Pulley
- MSD Plug Wires
- Dynatech Longtube Headers
- Catless Midpipes
- Flowmaster Catback Exhaust
- Lingenfelter Cold Air Intake
- Spec 2+ Clutch
- Spec Billet Steel Flywheel
- GMM Race Ripshifter
- Diff Technics 3.91 Rear Gears
- BMR Strut Tower Brace
- Pedders Strut Mounts
- Pedders Strut Mount Bearings
- Pedders F Castor (Radius Rod) Bushings
- Pedders GSR F Struts
- Pedders GSR R Shocks
- Pedders 1" Drop F Springs
- Pedders 1/2" Drop R Springs
- Pedders F Endlinks
- Pedders R Endlink Bushings
- Noltec Diff Mount Insert Bushing
- Noltec R Sub-Frame Bushings
- Noltec R Inner Control Arm Bushings
- Pedders R Outer Control Arm Eccentric Bushings
- ARP Wheel Studs R
- Hotchkis Sway Bars
- Wilwood Brakes, 13" F
- Wilwood Brakes, 12.2" F
- SST Flex Lines / Fittings
- Budnik M5 Wheels, 18x8 F, 18x9 R
- BFG gForce Sport Tires, 245/40-18 F, 275/35-18 R
- Blue Intrument Cluster Color
- Blue Radio Color
- Blue HVAC Control Color
- Blue Button Colors
- Aeroforce Scan Gauges (custom billet bezel and black face)
- SCSS Gauge Pod
- White Interior LEDs
- Spoiler Delete Trunk (welded and painted)
- CV8R Taillights
- 35% Window Tint
- CARMotorsports Hex Floor Mats
- California Car Covers Dustop Cover
- '05/06 Inner Diff Stubs (low mile)
- Pedders F Inner Control Arm Bushings (NIB)
- Pedders F Control Arm Radius Rod Bushings (NIB)
- Noltec R Outer Control Arm Bushings (NIB, to replace Pedders eccentrics)
- JHP Lip Spoiler (1st Gen, needs to be finished)
- PYFC Exhaust Inserts & Tips (need to be finished)
- '05/06 OEM GTO Hood (to be repaired & painted)
- Stock Struts
- Stock Springs
- Stock Sub-Frame Bushings
- Stock Endlinks
- Stock Spoiler
- Stock Rear Gears
- Stock Brakes
- High-flow Cat Converters
- Stock HVAC Controls (extra)
- Stock '04 PBM Hood (extra)
- SpeedInc T/C Reverse Module (needs transistor replaced)
