ls2 trans am th400 dana s60 11.6 motor-10.5 nitrous
*possible trades* for a truck an some cash
*motor has a tick that sounds like a exhaust leak. havent tryed messing with it cause im broke. car still goes 11.6 on motor
$12,000
53,432 miles on car
t-tops,leather/ power everything
monsoon system
a/c still in car nothing is missing from this car from the factory
all the drivetrain was done in the last 11 months!!!!
Motor
ls2 crate motor
hardened pushrods
torguer camshaft
QTP headers with x pipe dumped
meziere electric water pump
fast 92mm intake
fast 90mm throttle body
nx nitrous wet kit
SUSPENSION/drive train
-dana s60 rear end
-dana s60 rearend cover
-4.10 tru-trac
-35 strange axles spline axles
-bmr cross member relocator
-umi adjustable torgue arm
-umi adjustable pan-hard bar
-subframe connectors
-bmr relocation brackets
-lakewood lower control arms
-lakewood subframe connectors
TRANSMISSION
*STOCK SHIFTER WITH RMVB WORKS AWSOME! true sleeper car
-th400 reverse manual valve body
-yank ss3600 stall
-BMR TH400 TRANS MOUNT
OTHER GOOD STUFF
-b&m trans cooler
-walbro 255 fuel pump
-hawk brake pads
my email is ls1sleeper@yahoo.com
or contact me at 586 863 3960
$12,000
53,432 miles on car
monsoon system
Motor
ls2 crate motor
hardened pushrods
torguer camshaft
fast 92mm intake
nx nitrous wet kit
-dana s60 rear end
-4.10 tru-trac
TRANSMISSION
-yank ss3600 stall
OTHER GOOD STUFF
-b&m trans cooler
-hawk brake pads
drags rims do come with it if somebody hurrys up an buys this otherwise im jsut going to part the car out cuz i need money to get my house soon. thanks
torguer 2 cam check up the specs i dont know off hand. its a stealthy cam sounds stock
