Looking for forced induction or H/C Fbody $15k or so...Must be close to Wisconsin.
Looking to get into a new vehicle. Prefer forced induction but would consider H/C built. Prefer 6 speed over automatic. Prefer t-tops or convertible over hardtop.
Trans Am, Camaro, Gto or Corvette.
Serious buyer who has the money ready to go.
--------------------------------------------------------------------------------need funds building new house neg. delivery or meet up
$18,000 HAVE CLEAN TITLE Im losing $25000 on this car email or text me at 803-646-1431 for photos dont call i will call you I will send pics via text or email pics on request
car makes 407 rwhp and 419 tq to rear wheels on motor and makes 547 rwhp and 559 tq to rear wheels on 150 shot and it dead hooks
2002 trans am / black and ebony leather interior
garage kept at all times doesnt get driven in inclement weather!!!!
gets really good mileage for the car
65,xxx miles
6 speed tremec trans
strange dana 60 rear end 35 spline chrome moly race gun drilled axles
true trac differential
4:10 rear gear
monster stage 3+ cluctch and fly wheel and hydraulics brand new install by RPM in Garner NC
pro 5.0 shifter
hurst line lock
ms4 cam "magic stick 4"
patriot gold double spring kit "valve springs"
pace setter long tubes / no cats
pace setter y-pipe
borla catback exhaust also magnaflow
all fully adjustable umi suspension / torque arm , lower control arms w/ relocation brackets, panhard bar, drag bar/ also umi sub frame connectors
(THIS WHEELS MAY BE SOLD WITH CAR DEPENDING ON OFFER MADE FOR PURCHASE OF CAR weld pro stars brand new 15x3.5 fronts and 15x10 rears with mickey thompson front runners and mickey thompson drag radials 295 55 15s brand new)
also 17 inch ws6 wheels with brand new nitto 555s tires
nitro dave nitrous express kit 150 shot plate kit with progreesive controller , dual window switches , purge, 10lb with remote bottle opener and heater installed by RPM in Garner NC
EMAIL ME /ALSO NO TIRE KICKERS/ ONLY TEST DRIVES WHEN CASH OR CHECK IN HAND / SERIOUS OFFERS NO JOY RIDES
65,xxx miles
4:10 rear gear
pro 5.0 shifter
hurst line lock
pace setter y-pipe
65,xxx miles
4:10 rear gear
pro 5.0 shifter
hurst line lock
pace setter y-pipe
65,xxx miles
4:10 rear gear
pro 5.0 shifter
hurst line lock
pace setter y-pipe
That must be the most valuable 65,000 mile 02 Trans Am in the world.
Trans am
I know this isn't anywhere near the area you are looking in but you seriously consider it. I would be all over this car if I would have seen it before I bought mine. This is a steal!
https://ls1tech.com/forums/vehicle-c...ew-driver.html
I have a black 99 ws6. 40k miles with a 6.0 in it that has about 3k on it since build last summer. Its a cam only car with a g5x3, 3.73 gear and 4k stall. Currently needs new piston rings but I would obviously work that into the price or could possibly get it fixed first. Either way would definitely be under your 15k and you could use the difference to throw on the heads of your choice and have a nasty H/C 6.0
Lemme know if you would be interested and I can send you a full mod list and pictures.
If you can push that 15k higher. Here is what I have to offer.
Here is the mods list. I don't know what the car is worth but I prob. have close to 35-40k into the car not including it.
Parts run down:
Car:
-2000 Trans Am with 24,000 miles on the body. Onyx black with a Glasstek hood.
-The rest of the exterior is stock with nothing else done to it.
-15x4 Prostars in the front with MT runners (new)
-15x10 Prostars in the rear with Hoosier 28x10 DOT slicks (almost brand new less than 10 miles on them).
Interior:
-Full leather interior, it's all stock. The seats look brand new since there is so little miles on the car. Stock Radio, stock speakers, stock carpet, etc...
-8 Point Wolfe Racecraft Roll Cage.
-All Autometer and AEM gauges.
Motor:
-Iron Block LQ9 6.0l built by HKE, it is now a 408.
-Eagle Forged Rods.
-Custom Wiseco -32cc Pistons with coated skirts and tops.
-Hell Fire Rings.
-Eagle Forged Crank.
-All ARP equipment in the block.
-TFS 225 Heads done over by Tony over at AFR.
-LS9 Gaskets.
-Harland Sharp Rockers, Comp springs, pushrods, valves, etc...
-I'm probably missing some things.
Trans:
-Rossler 4l80e transmission reworked.
-With Rossler Tree Breaker 4L80E Ross-Lock
-Moroso Deep Pan.
-Pro Torque 1600hp converter that has a stall speed set at 3800.
-Line Lock, Stall Lock, all installed.
Suspension:
-QA1 Coilovers and struts up front.
-Strange 300lb drag shocks in the rear.
-All New BMR bushings
-Spohn LCA's
-Spohn TQ arm.
-Spohn Panhard Bars.
-BMR Turbo K-member up front.
-BMR Engine mounts
-I think I am def. forgetting some parts here
Turbo Kit:
-S91 turbo that was just redone by Forced Inductions (balanced, checked and spun).
-All powder coated cold side
-All coated hot side
-31x24x4 Intercooler
-Dual Tial 44mm WG's
-Turbosmart 60mm BOV.
-It has a 4" Electric cut out.
-AMS 500 Boost Control
-I made the kit to look like it was almost stock for the sleeper look. It has a 5" DP going to a 4" electric cut out than it merges with a Magnaflow exhaust for the total street look and sound.
-This is all brand new with 0 miles on it.
Fuel System:
-NastyPerformance Custom Race fuel tank with gauge sender
-MagnaFuel 4303 fuel pump (Great street pump)
-NastyPerformance Billet fuel rails
-NastyPerformance Billet Y-block
-Fuelabs billet fuel pressure regulator w/boost ref. -Fuelabs billet pre stainless steel fuel filter
-Fuelabs billet post stainless steel fuel filter
-Aeroquip -10 braided stainless feed fuel line
-Aeroquip -8 braided stainless return fuel line
-NastyPerformance hotwire kit
-FIC 125LB/hr High Impedance Injectors.
Rear End:
-Moser Ford 9" in the rear
-3.73 Gear Set
-Strange Center Section
-Steel Drive Shaft
-Etc...
Everything that I have listed has less than 500 actual miles on it. So All of this stuff is almost brand new. I am sure I am missing a few things but this is kind of the narrowed down list.
This car makes 1xxx HP.
Parts run down:
Car:
Interior:
Motor:
-Eagle Forged Rods.
-Hell Fire Rings.
-LS9 Gaskets.
Trans:
-Moroso Deep Pan.
Suspension:
-Spohn LCA's
-Spohn TQ arm.
-BMR Engine mounts
Turbo Kit:
Fuel System:
Rear End:
-3.73 Gear Set
-Steel Drive Shaft
-Etc...
Ha wow small world. Im ted's friend that came in the one day to get my transam. I knew that was benchmark when I saw the pictures!
Well I can vouch for the car above thing is awesome in person. Why the sale didnt you just finish that?
Consider that ^ a free bump....not trying to clutter the thread.
