Hard to put manual in R.
Any ideas? Sometimes I have to play with the clutch for it to feel like it went all the way into R. But every time, it's hard to put in R.
It is usually a reasons listed blow why your car wont go into reverse
1. Your clutch is not disengaging
A. Bad master
B. Bad slave
C. Bad fluid
D. Bad pilot bearing
E. Input shaft is hitting the back of the crank shaft
F. Your throw out bearing is stuck on the slave cylinder
2. Your transmission wont go into reverse because
A. Bad syncro
B. Broken keys
C. Broken plastic bads on shift fork
Make sure that you have your clutch fully disengaged. If it wont let you put it into reverse, put it into first grear and move forward a little then try it again. Good luck.
P. S. We also rebuild transmissions if you would like us to fix it for you. Give us at CMS a call for more info.
A. Bad master
B. Bad slave
C. Bad fluid
A. Bad syncro
B. Broken keys
A. Bad master
B. Bad slave
C. Bad fluid
A. Bad syncro
B. Broken keys
word...
im calling bad hydraulics, easiest and cheapest thing to fix.
do the drill mod, grab a mighty vac and some gm dot3 brake fluid flush the system after the drill mod and bleed with a mighty vac, if the problem still persist you will have to hit up this guy^^^
LS1TECH Sponsor
word...
