Western Members CA, AZ, NV, UT, CO, NM, HI
question
Old Feb 13, 2009 | 10:29 AM
snugans310's Avatar
Default question
i heard from someonr that there a rubber you can put between you y pipe and body to stop the rattle you guys heard bout this if so were can i get it
Old Feb 13, 2009 | 10:31 AM
fast01z28's Avatar
havnt heard about rubber, but ive heard of exhaust shops welding on an extra bracket to keep them separated.
the only rubber i can think of that can MAYBE withstand the heat of exhaust is heater hose.
Old Feb 13, 2009 | 01:28 PM
ss.slp.ls1's Avatar
+1. Any exhaust shop can add extra hangers with rubber bushings to eliminate rattling. Should be cheap too.
Old Feb 13, 2009 | 11:23 PM
MrElectric03's Avatar
Had CMS put some extra hangers on my Y pipe to keep vibration down...worked like a charm.
Old Feb 13, 2009 | 11:29 PM
lowerthanyou00's Avatar
ive heard of people cutting up pieces of tire and sticking em in there but i def wouldnt recommend it, hangers is the way to go
krazy4's Avatar
I have heard of some people using a piece of heater hose, although the right way to do it would be to take it to an exhaust shop.
Old Feb 13, 2009 | 11:42 PM
jsteele90's Avatar
thunderacing makes a y pipe bumpstop that helps to eliminate this problem
Old Feb 14, 2009 | 12:44 AM
BackInBlack02's Avatar
this is just in time, I took my LT1 to a shop in HB today to get the bumping looked at and they said the fix is to remove the Ypipe and add a "curved piece" where the bump occurs, fixing to go get it done tomorrow.
I found the Thunder Racing Mufflex LS1 Ypipe bump stop hanger, http://www.thunderracing.com/catalog...id=528&pcid=54,
will this work on an LT1?
I need to know before I go back tomorrow to get it done.
Old Feb 14, 2009 | 06:14 PM
BigDaddyBry's Avatar
^^^I have one of those if anyone is interested.
