Who's got a system in their F-body?
old pics but i had 2 rockford he2's with a power 750. it was loud as ****, and the camaro cabin is perfect for a system. nothin top notch like the lucky guys with the previous posts, but it was alright. it was fun
my god.
finally a man with a true system.
Will if you're going to do ANYTHING to your system I suggest you do something like this. You do put some of the best **** in your car so dont stop now. This is a complete system. Blows everything else outa the water in this thread. Only thing i'd add if it already isnt is some sound deadening.
Mine is a single Alpine type R 10" in a custom side box so the t-top holders are usable, a Fosgate P325 and a P450 powering the sub and the type S components in the sails, doors and tweeters in the doors, and a 7" indash dvd player to control all of it.
I like everything about. Its not to overpowering unless I want it to be. The place that installed it did a nice clean job...I thought about installing another sub on the other side but now I have something else in there
ive been buying stuff slowlyto form my system. Its going to be a very mild system, already have all i need just need to DO IT:
Double DIN Nav - Pioneer AVIC-D3 (already installed)
Front Components
running active(no passive crossover):
6.5" RE RE midbass drivers
Alpine SPX tweeters
No rear speakers. No need for them
1-10" Sub- Image Dynamics IDQ
Amps:
McIntosh 75 x 4 Channel for the fronts setup (1 channel each)
Alpine 600D for the IDQ
Alpine External Crossover for the whole system to tune it and a good amount of SecondSkin Sound Deadner
Front Components
Alpine SPX tweeters
Amps:
I have 2 alpine type Rs, with 2 pdx 1.1000 rms amps powering them at 2 ohms, 2 caps, yellow top, ida x100 head unit, alpine speakers and a alpine f600 4 channel amp. Using 0 guage wire from the battery. Sounds real good, the subs do a real good job, they hit the lows really good and can get loud as well, they are in a sealed box but I think Im gonna change to ported. Check out these guys, their located in santa clarita, best prices... period.
http://www.sonicelectronix.com/
#32
Damn, thats sick bro. I'd love to check that thing out next time i'm down at CMS.
haha, you're right Cesar. The 2 badass 12's is somewhat excessive for me though (even though theyre probably fun as hell)
I went with an AE AV12H In a 1.5 cu ft sealed box with an Mmats D1600.2 powering it with 1200watts rms @ 2ohm. I currently have 4 Alpine Type S 6.5's up front(sails using the feeds from the hatch speakers) ran on the stock amp which sounds surprisingly good for what they are and an Alpine headunit I'm going to add an amp for highs, new speakers and a headunit soon.
I finally finished the majority of the sound deadening also, damn that ****'s a pain!!
Nice thread guys
Nice thread guys
#33
Kenwood KDC-X991, 2 zapco symbilink transmitters for front and rear speakers go into 2 zapco AG350 (ea. 2ch. 100rms@4ohms)amps powering a front set of Diamond Audio hex s600s component speakers, and in the sail panels a set of CDT HD-M6+ subs.
For the subs I first have a Audio Control Epicenter running into a MMATS D3500.05 (2700 watts rms) @ 1/2 ohm,then powering 2 Image Dynamics IDMAX10 d2's, each in 1.6cu.ft. w/external aero port @29hz.
For sound deadening : under the dash, above the headliner, on/in sail panel area, on/in the doors, floor area, rear fender area, hatchlid, and body bag area!
All done with 1-2 layers of secondskin damplifier, and overkill pro.
and finally under the car sprayon truckbed liner under front and rear seat area and rear trunk area.
That should be about all of it!
And 1 run of 4 gauge, and 1/0 gauge power wire running to the amps.
So loud it hurts!
So loud it hurts!
#34
So loud it hurts!
So loud it hurts!
#37
My PowerMaster "Proof of performance" card shows a tested output of 250amps @ around 1900(engine)rpm.
http://store.summitracing.com/egnsea...115+4294880779
#38
For the "Big 3" I'm using 1/0 gauge, alternator is a Powermaster 200amp pt#58203(I've had mine for probably 2yrs.).
#39
#40
this is what got in my hawk. 12" jlaudio w7, jlaudio 1000/1 amp for sub, jlaudio 300/4 for my mid's and highs, mids an highs are FOCAL audio speakers. I made my own box an also installed it all. System sounds bad *** but heavy as ****.
