installing electric cut out switch
FYI...sorry but i know this is a noob question..
.this is my first time doing it..Thanks fellas in advance...
what you can do is, under your console in the wiring for TCS/ASR (traction control) use the pink wire. This will do the same thing for you and it's close to wiring too.
your best bet is to make a new fused circuit with a relay...
this way you can run your own power source and ground path to your device...you can use almost any key power source as a trigger as well...
Also, i my Z28 didn't come out wit traction control...
One other thing. where i have my fog switch and another plaque that says camaro there is another switch that i have but is non-operational. When i took out the console to set up my switch, there are wires running to that non-working switch. has anyone figured out what thats for?
