Western Members CA, AZ, NV, UT, CO, NM, HI
Battery problems! HELP! ill buy beer
Old Jun 28, 2009 | 11:55 AM
0235SS's Avatar
Exclamation Battery problems! HELP! ill buy beer
My yellow top sucks *** . I ether need to run a second battery again or I dunno. Any ideas guys? My sound system is ******* with my volt gauge a lot. (I have the BIG 3 done) I need a new better battery.. any ideas welcomed plz.
Old Jun 28, 2009 | 12:08 PM
CaliforniaBoy5's Avatar
do you know what your voltage reads at with the car off and then with the car on?
Old Jun 28, 2009 | 12:39 PM
MrElectric03's Avatar
I have seen alot of optimas fail very quickly, ill never waste the money on one.
Knowing the actual voltage would help.
Old Jun 28, 2009 | 01:16 PM
SSMOKIN_Y2KSS's Avatar
u have a capasitor? ....my suggestion is head into a kragen have them do a charging system test on ur car..if it fails u need an alternator ...get a new battery check all your grounds..make sure your amps have good clean grounds and make sure u have a capasitor...good rule of thumb is for every 500 watts of ur sound system u should have a 1 farad capasitor
Old Jun 28, 2009 | 01:43 PM
hlaalu's Avatar
how is the battery and voltage when you don't turn on the radio?
Old Jun 28, 2009 | 03:28 PM
ZexGX's Avatar
x2 on the capacitor. If you don't have one, you should get one ASAP. You said that you had the Big 3 done so that means you should already have a new alternator. What kind is it and when did you install it?
Old Jun 28, 2009 | 05:22 PM
0235SS's Avatar
its only a 160amps stock is 105 i believe. i know when the car is off the check gauges light is on, i think its my fucken battery.. which is the best kind of battery to get?
Old Jun 28, 2009 | 05:49 PM
m6ttop's Avatar
WTF is the big 3 and u better have a cap!!
Old Jun 28, 2009 | 05:53 PM
ZexGX's Avatar
Do you have a capacitor or not? They act as an additional battery so that your main battery doesn't take a hit every time the bass hits.
https://ls1tech.com/forums/stereo-electronics/883797-big-3-upgrade-200-amp-alternator.html
Old Jun 28, 2009 | 07:10 PM
XpEdItIoUs's Avatar
GOOD advice here bryce. But when do I upgrade to a Flux Capasitor?
Old Jun 28, 2009 | 08:36 PM
m6ttop's Avatar
Lol page not found
Old Jun 28, 2009 | 08:45 PM
camarosam22's Avatar
-2 on the cap, the only time the cap is being used is at high volumes when your really pulling power, besides that it doesnt do ****. I have had my yellow top for 2 years now and have runned it dead at least 100 times, still works.
I would check your alternator.
Old Jun 28, 2009 | 08:58 PM
hitmanws6's Avatar
you should have came by sears today, i would have checked it out for you. if it is in fact your battery, upgrade to a red top or a die hard platinum. they are pretty much the same thing, except the die hards last longer
Old Jun 28, 2009 | 09:08 PM
0235SS's Avatar
thank you guys
Old Jun 29, 2009 | 02:32 PM
99Bluz28's Avatar
If you've run you battery down until it's dead, and only jumped it to get it going again without later putting it on a good battery charger, that's at least part of your problem.
FYI,
Your alternator was never meant to recharge a dead battery, only to keep it topped off.
Also, a cap is only a band aide.
If you really want one I have a 2 Farad Tsunami Capacitor with a built-in voltage display I pulled out of my system that 'll sell you for $50!
Old Jun 29, 2009 | 03:07 PM
Caps are gay. They are a band aid as said before. Get a good battery or even a second one if your audio warrants it. Here is a good read to understanding a car audio capacitor and why you shouldn't get one.
http://www.isyougeekedup.com/car-aud...aste-of-money/
