Western Members CA, AZ, NV, UT, CO, NM, HI
50K Service? What to look for?
Old 07-03-2009, 04:51 AM
DobsZ28's Avatar
Default 50K Service? What to look for?
Cars got ~ 47,000 miles, and I was going to get it serviced. Just ordered new pads and slotted rotors, and I was going to have my transmission flushed, rear end fluid changed out...I've been hearing a pretty annoying and persistent clunk/rattle from underneath my car when it's idling sometimes, and the power steering might be leaking..
Basically, what kind of problems have you guys run into around 50K, and what sort of maintenance would be wise to do at this point.
Old 07-03-2009, 12:18 PM
hlaalu's Avatar
hmmm i would lube up your suspension, check the coolant, check/replace spark plugs, definitely check your alternator because my power steering pump was leaking too and it's right over the alternator so my alternator crapped out. hmmm I just woke up and that's all I can think of but im sure there is more to check.
Old 07-03-2009, 09:34 PM
DobsZ28's Avatar
^^^^ yeah i've heard about the power steering issues with LS1's, them leaking and killing the alternators, i'll have them take a look
thanks for the advice...20 views and only 1 response...thanks guys. lol
Old 07-03-2009, 09:40 PM
hlaalu's Avatar
lol. you might want to also check all the hoses and wires you can see for cracks or other damage. the mileage doesn't really matter cause they have still been sitting there a long time. make sure the air filter is still in good shape. oh and you might want to flush out the brake fluid and check those lines while the the new rotors and pads are going in
Old 07-03-2009, 09:44 PM
brynnda's Avatar
you just hit 47k? f you. im sure thats what everyone who saw this thread was saying
Old 07-03-2009, 09:49 PM
lowerthanyou00's Avatar
clunk rattle, prolly trans mount everyone breaks em dont forget to get your new cats if its 2k or newer
Old 07-03-2009, 10:05 PM
DobsZ28's Avatar
^^^whaaaat? new cats? it's an 02...
is trans mount super expensive?
Old 07-03-2009, 10:49 PM
trans mount is cheap and easy, they break easily if you got a heavy foot
and for cats i wouldnt really worry untill you start throwing codes. but read post 7 just so you know for in the future. follow this link https://ls1tech.com/forums/pontiac-f...t-05513-a.html
Old 07-03-2009, 11:58 PM
hlaalu's Avatar
yea you might as well get a poly mount, they are only a little extra
Old 07-04-2009, 12:24 AM
Jeremy 92 RS's Avatar
This is a good idea if you don't mind the extra feedback you WILL feel and hear in the car. They are cheap, like $30 cheap. Even Auto Zone carries em usually. The rubber tranny mounts absorb some of the vibration obviously, but they are prone to break easily, especially if you like to actually DRIVE the car. I broke two in a few month period.
Trans is also due for service at 50K if you're an Auto. The gear oil in the diff would be a good idea if you haven't done it yet too, uses 75W90 synthetic.
Old 07-04-2009, 03:55 AM
DobsZ28's Avatar
thanks for all the input...cars a 6 speed..wanting to get everything taken care of, then take it up to CMS for LT's, Y, and a tune.
Old 07-05-2009, 10:11 PM
-98-Z28-Darkness-'s Avatar
good information my car also has 47k right now im planing on doing the gear fluid and coolant.
Quick Reply: 50K Service? What to look for?
