What cable type for positive battery lead?
Hey everyone,
I actually just need to replace the section of cable that fried. Seems like the cable was touching metal. The lead I'm talking about is the one that connects from the rear of the alternator by a bolt to the battery (positive side). What type of cable is that? I'm sure I can't use the same type of low number gauge cable as a stereo system power wire. Should a butt connector work for this type of application? I'm thinking of re-routing the cable so that it doesn't run near the rack and pinion steering assembly, thus making it slightly longer. And yes, I had wrapped up the cable in high temperature conduit, and still it became so hot that it went through the wires in the cable.
Thanks.
Thanks.
bigger isnt going to hurt, on my old camaro I had 2 gauge routed to the alternator added to the existing factory wire. if you do not have any electrical hogs like HIDs and a stereo system I am sure 4 gauge would be a suitable option and upgrade.
I do have HID's, both headlights and fogs. Also have a stereo system, but it's mostly the subs that take up the most power. I really don't hit the bass that many times though.
