Western Members CA, AZ, NV, UT, CO, NM, HI
A/c Issues help needed.
Old Jul 15, 2010 | 11:25 PM
RPD_Vette84's Avatar
Default A/c Issues help needed.
ok went to charge my a/c and it started to get cold but then i shut off the car and started it back up and hot again but wouldnt get cold. added some more freon until it wouldnt take anymore and it wont get cool anymore. anyone know what it could be? oh yeah as soon as i put the freon thing on with the gauge the gauge maxs out.
Old Jul 15, 2010 | 11:26 PM
0235SS's Avatar
gtfo? same problem here
Old Jul 15, 2010 | 11:34 PM
jsteele90's Avatar
system is overserviced for one. dont ever buy those fix it kits
Old Jul 15, 2010 | 11:46 PM
both my friends just did their cars today and it worked fine. got them both down to about 40 degrees. according to the little probe thermometer they stuck in the vent. it felt damn cold.
Old Jul 16, 2010 | 12:12 AM
0235SS's Avatar
do u get cold air at all? how about when you try running the AC does it only blow on the bottom? (Regular temp. air)
Old Jul 16, 2010 | 12:20 AM
it started to blow cold for a little while and then we thought maybe i didnt have enought freon so i went to the store and when i got back in the car it was hot again. it wont go cold like that time before i shut off the car.
Old Jul 16, 2010 | 12:22 AM
0235SS's Avatar
yeah man same probl. over here. lmk wussup keep me updated plz my cell is 714-724-1295 just text me bro
thanks man best of luck to u
-Danny V
Old Jul 16, 2010 | 12:37 AM
no prob. let me know if you find anything.
Old Jul 16, 2010 | 02:35 AM
LS1Adam84's Avatar
I am thinking your compressor is bad, but I am not 100% sure on that, it does not look like you have a leak it just looks like it cannot take the freon and make it cold. Then again I could be wrong and this would be nothing knew just tossing ideas out there.
Old Jul 16, 2010 | 03:05 AM
SoCal01z28's Avatar
It's really important to get the capacity right. Sounds like you overcharged it just enough to not blow off excess pressure but it can't get the cold side down the right pressure. You need a manifold gauge set to see what the cycle time is and the hot/cold side pressures.
Old Jul 16, 2010 | 10:59 AM
SUCK MY SS's Avatar
id also double check your vac. lines that go to the hvac controls... if they develop a leak the ac wont work right either.
Old Jul 20, 2010 | 10:40 AM
allblacksrt4's Avatar
take it to that ac guy dino knows he is good and super cheap.
Old Jul 20, 2010 | 11:01 AM
0235SS's Avatar
whats the status on the AC bro|?| i cant stand driving with no AC!
Old Jul 20, 2010 | 11:05 AM
ss.slp.ls1's Avatar
Couple things to check, as mentioned, check the vacuum lines going to and from that little check valve over by the PCM. Any leaks and your AC might not work properly. Also check the vacuum lines that run over to the HVAC controls.
Another thing to check is to actually look at the AC compressor and make sure that your AC clutch is engaging.
And finally, you need to check the under hood fuse blocks and make sure your AC/Cruise fuse is not blown.
Old Jul 20, 2010 | 12:29 PM
well i know the clutch is turning on. havent go tto check anything else yet. with the pressure i emptied the system and then filled it and it would go to a good pressure but i shut the car off and turn it back on and it shoots to max. i will have to check the vacuum lines and stuff after i get the car back from the exhaust shop.
Old Jul 20, 2010 | 12:39 PM
ss.slp.ls1's Avatar
well i know the clutcc is turning on. havent go tto check anything else yet. with the pressure i emptied the system and then filled it and it would go to a good pressure but i shut the car off and turn it back on and it shoots to max. i will have to check the vacuum lines and stuff after i get the car back from the exhaust shop.
That's usually not enough. You have to empty it and then add a vacuum to the system before adding freon. Most people don't do that. I think you want to get to about 750 microns before you add freon to the system. My buddy can redo your system for cheap (he works for refrigeration company), you just have to go to his house. He's already hooked up a few members here on Tech.
Old Jul 20, 2010 | 01:53 PM
ill probably end up just takin it to a shop but by the time i pay off my exhaust guy itll probably be winter lol.
Old Jul 20, 2010 | 03:03 PM
ss.slp.ls1's Avatar
Don't my buddy charges 40 bucks to evacuate and recharge a system, including freon. He has all the professional equipment, because it's his profession, lol.
Old Jul 20, 2010 | 03:30 PM
alright maybe next pay check. ill let you know
Old Jul 20, 2010 | 07:22 PM
Jeremy 92 RS's Avatar
It sounds like you overcharged the system. SoCal01z28 hit it right on the money.
Those DIY AC recharges from the parts store can be ticking time bombs, and even doing it with just the gauges is not 100% accurate. If you want it done to spec, its best to be vacuumed out and recharged by a machine.
