Need help trying to find gear instal kit!!
so i have the motive 373 gears part # G875373 that im trying to instal into a ls1 342 rear end. im trying to find the instal kit for it.
will this kit work? when i click application summit says its only for 1980-1996, but this seems to be the same kit Texas speed sells under the 98-02 f body section.. any help on which kit to buy?
http://www.texas-speed.com/shop/item...mid=50&catid=6 (the tsp one suggested for f bodys)
the one on summit with the same part number but says its for a gm 8.8 12 bolt
http://www.summitracing.com/parts/RAT-315K/
so i basically need to know what kit to buy for the motive 373 gears i listed above. part # G875373
help would greatly be appreciated.
What you need to look for is an install kit for a 7 1/2 GM rear, the summit one sounds wrong. If you want I can get you the master install kit with timken bearings, we can meet up since you're close by.. let me know.
Rick
Rick
thanks bro
you can also text me 24/7 510 342 6722
yea the summit one does seem wrong.. i hate dealing with summit.. they are using the same product number as tsp but a totally diff product description. lmk the price and how soon you get it... (you say just a gm 7.5inch, but arent there diff gm 7.5 i.e for trucks, old *** cars, ls1 camaros? or do they all use the same instal kit?)
thanks bro
thanks bro
