Western Members CA, AZ, NV, UT, CO, NM, HI
building a ls2
Old May 16, 2011 | 08:37 PM
manwithhate's Avatar
Default building a ls2
I'm thinking about building a ls2 to drop in a camaro f body. With ls6 mainifold and ls9 heads. With a decent cam. But not sure. If its a good idea and I don't. Know what all has to be done any help is appreciated
Old May 16, 2011 | 08:58 PM
djsanchez2's Avatar
LS9 heads? Why not L92/LS3 heads?
Also LS6 intake will not work with any of the new heads. They are square port, the LS6 intake is cathedral port.
Do you want to keep it smog legal?
A solid low buck combo would be the LS2 bottom end, L92/LS3 heads, L92/LS3 intake, custom cam, LT's, 3" exhaust, nitrous. (assuming smog is not an issue)
check here for any compatibility issues between gen III and IV.
http://www.fbparts.com/ls_general_charts.htm
Old May 16, 2011 | 09:01 PM
tripblackls1's Avatar
honeslty if i were you i would call a forum sponsor and have them set you up a good combo
Old May 17, 2011 | 12:28 PM
ss.slp.ls1's Avatar
Yup, I love that simple combo, easy way to make 460+ rwhp NA.
Old May 17, 2011 | 01:17 PM
Sounds good I'm trying to get as close to 500 hp without nitrous and wanna keep street legal
Old May 17, 2011 | 05:08 PM
djsanchez2's Avatar
Once 2013's new smog laws (no more tailpipe checks) roll around you'll be set on a combo like that being "street legal" until then you'll have to keep the cam a bit tame to maintain smog status.
Hit up PatrickG or PredatorZ either of them will be able to spec you a custom cam to suit your specific needs and make the power you are looking for. Just bypass all the shelf ready cams, they are too generic for what you need.
Old May 17, 2011 | 06:27 PM
dyls1's Avatar
PatrickG spec'd my cam and it really wasn't that much more for my custom grind versus an off the shelf cam. I was more than happy to pay a few bucks more for something actually tailored to my application and by a few bucks I think it was around 30 or 40 extra. Poor memory (may have been a little more) but I remember it was well worth it
Old May 18, 2011 | 12:43 PM
General_Joser's Avatar
can you explain this new smog law please
Old May 18, 2011 | 01:32 PM
djsanchez2's Avatar
There is an entire thread on the subject in this section.
The gist of it is: Anything from 2000 on will drop the tailpipe testing and only be subject to OBDII computer scan and visual.
It is said that as long as the computer is not throwing codes, most any cam/heads combo with a good tune and emissions devices in place will pass.
It is also suspected that if a tech is found who will overlook "certain items" *cough* LT's/ORY *cough* one can pass with a pretty stout set-up.
Old May 18, 2011 | 01:50 PM
wow very nice
Old May 18, 2011 | 07:29 PM
CHEVYBOYZ_86IROCZ28's Avatar
nice that motor will be sick
Old May 19, 2011 | 01:48 AM
nevrlift13's Avatar
**** cats ill nver run em again...
