SOMEBODY CLIPPED MY REAR-END!!!Need Help!!
I didn't use a fuel pressure tester but I did remove the cap on the fuel rails an turn the key to on pos. to prime the fuel pump but not one drop of fuel came out...
And as for the pinched soft lines on top.my car was hit good enough to make the gas cap stick out about a half inch due to the qrtr panel being pushed in.if I wantd to check the soft lines can I seethem from underneath or do I hav to drop the tank?
Ok...I'm starting to pull the car apart.Not as easy as I thought it would be.I remove the body clips from the bottom half of the bumper but I noticed there are a few more in between the bumper and the quarter panel.I can't seem to reach those unless I remove the quarter panel??is this necessary?
