CARB Legal LSX Swap in CA Questions
At the end of the year I am moving back to California. I have a 96 ranger that I plan on doing an LSX swap into but just need to figure out what motor I can use to make it CARB legal cause it will be my DD. Can I get the motor out of a car or does it need to be out of a truck since it is going into a truck? Also is there anyone someone could recommend me to that I could get the motor and transmission mounted up? Thanks guys
to motor swap in CA and have it be legal there is truely only one base requirement.
Motor installed in target vehicle must be newer than year of target vehicle, and smog as though it is in the car the motor was originally intended.
You can put any LS1 in as long as it smogs like the car its from. The easiest thing to generally do is use a 2001-2002 ( PCM ) as that is how the smog machine acknowledges engine year. ( as 01-02 f-body has few emissions )
you'll get it.
you'll get it.
Edit: straight from the BAR guidelines - "CLASSIFICATION
Don't mix engine and vehicle classifications which will degrade the emissions certification standards. For example, a heavy–duty engine cannot be installed in a light–duty exhaust–controlled chassis even if they have the same displacement. Non–emissions controlled power plants such as industrial or off–road–use–only engines may not be placed in any exhaust–controlled vehicle."
California EPA website:
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
Vehicles converted to 100% electric drive, with all power supplied by on-board batteries are considered in compliance with the engine change requirements. All fuel system components must be removed prior to inspection. For additional information contact the ARB helpline at (800) 242-4450
Thanks for all of the great info guys! So I would probably have an easier time putting a 5.3 from a silverado than an LS1 from a car? Am I understanding that correctly? The only thing I don't like about the truck motor is that it is an iron block instead of aluminum like the LS1
Lee, I have heard this is more of a true statement with CA and BAR.
Heck put an LM7 in it and call it a day, you could even bore it to LS1 size use stock LS1 pistons, through truck heads on it, increase the SCR a little, and a small cam and there ya go, BAR legal and making power all at once. Sorry put the cam in after getting the swap certified just in case they want to get douchey on ya.
motor wise its gonna be hard for them to tell a LS1 from LS6 to a LQ4/9 , since they all look identical , and if you painted the block black , it would be harder to tell a LS1 from a truck motor , though there is some newer 5.3's that are all aluminum
just make sure the tune in the computer used is what its supposed to be
Lee, yeah very true but they are not going to take the heads off to see if you have a larger piston size lol.
you can have a 900ci LSX in the car as long as it looks stock , and idles close to stock and will pass the sniffer , no one will be the wiser
or since the LS7 is a newer motor , you can get it swapped in legal like if you follow their rules and use most all the newer emissions equipment
There's a website; www.enginefactory.com that has some of the nicest drop in LS motors ever seen.
When I contacted them, they told me their motors would not pass CA smog.
Their LS7s are nasty and would really be nice in a bird.
