Western Members CA, AZ, NV, UT, CO, NM, HI
Any shop for brake upgrades? in SoCal
Old 01-03-2012, 02:49 PM
SiCkRs's Avatar
Default Any shop for brake upgrades? in SoCal
Im looking for a shop that could modify my spindle and make me a hub and brake bracket for some 5th gen brakes. Around Los Angeles would be much better
Old 01-03-2012, 03:36 PM
nomoneyz's Avatar
Why not just do the c5/6 upgrade? Whole kits are under 1000 bucks.
Old 01-03-2012, 06:25 PM
fast01z28's Avatar
those mods might not be needed...look for a thread on using CTS-V brakes. the 5th gen calipers are similar and should go in similarly.
Old 01-03-2012, 06:56 PM
TPI TERROR's Avatar
i think he needs this for a third gen.
on our cars we have to modify our spindle, tap and drill onto the oem spindle. machine down a rotor for a hub assembly, longer studs, custom caliper brackets, hardware etc etc
Old 01-03-2012, 08:53 PM
nomoneyz's Avatar
I didn't know as he didn't specify for what car I just assumed 4th gen. I don't know much about 3rd gens but I know they make a bracket kit for the 3rd gens also to use c5/6 stuff as well.
Old 01-04-2012, 11:26 PM
fast01z28's Avatar
im with 'nomoneyz' on this...the OP didnt specify the year/gen. I assumed that the car in question was like 95% of the cars on this site...late 4th gen.
Old 01-05-2012, 12:48 AM
TPI TERROR's Avatar
yeah i got you guys, i know him personally thats why i know he has a 3rd gen lol
i paid a good amount of $$ for my ctsv brembo which was a complete all new kit. idk of anyone nearby who does the work.
but my brother did his conversion him self but he bought all individual parts needed for the conversion. came out cheaper
Old 01-05-2012, 03:16 AM
LS1Adam84's Avatar
Wait how much do you machine down a rotor assembly? There is a certain amount you can machine a rotor down to, if you do anymore you are just plain stupid. I do not know the measurements off the top of my head but seriously? You would rather machine down a rotor instead of buying the correct brake setup? I am sure someone makes a brake upgrade for third gens.
Old 01-05-2012, 10:23 AM
TPI TERROR's Avatar
i forgot your adam and you know everything.
you used a stock 82-92 rotor to be machined down into a hub.
like i said i bought my kit new since they sell kits for thirdgens.
Old 01-05-2012, 01:51 PM
SiCkRs's Avatar
Sorry for not being specific tpi terror is right i am doing this upgrade on a thirdgen i need to find a shop with a cnc machine that i could give them the pdf file i have for they could make the brackets i need.
Old 01-05-2012, 02:43 PM
LS1Adam84's Avatar
No I don't know everything but there is a Max amount of machining you do to a rotor before they are unusable. How exactly do they machine it? Not the rotor surface correct?
Old 01-05-2012, 03:00 PM
nomoneyz's Avatar
I sent you a pm op to the place I got my kit from for my Skylark. Check them out, they are awesome to deal with and really know their stuff.
Old 01-05-2012, 03:38 PM
SiCkRs's Avatar
What they do is cut of all the rotor surface and only leave the center and machine it in a taper that way it looks like a hub just like fourth gens have.
Old 01-06-2012, 01:01 AM
90z
90z's Avatar
I found a place down the street from me that might do it...Ill see tomorrow.
Old 01-06-2012, 01:12 AM
SiCkRs's Avatar
Thats great please let me know.
Old 01-09-2012, 03:51 AM
CyberGrey Z28's Avatar
Plain stupid
http://lukeskaff.com/?page_id=369
SickRs, I might have the correct drill and tap to modify the spindles if you are going C5. I think the V setups use different threaded bolts?
Old 01-10-2012, 06:48 PM
90z
90z's Avatar
my guy did a good job on the taps and hub....i just need a bracket made. let me know if you want his info and if you found a bracket source yet
Old 01-17-2012, 02:02 PM
SiCkRs's Avatar
90Z i got the info off you on tgo thanks.
And cyber gray z28 i think its 9/16 for my spindle and brackets according to this
http://www.thirdgen.org/techboard/br...illac-cts.html
Old 01-29-2012, 12:46 PM
90z
90z's Avatar
bump.. i need someone to cut me the brackets..
Old 01-30-2012, 10:49 AM
TPI TERROR's Avatar
Those aren't hard to find
Kore 3
And bigbrakesupgrade
Wanting to get them locally is another story
Quick Reply: Any shop for brake upgrades? in SoCal
