Help on Camp Pendleton.....
so I put a code reader on my car and it read P0335 Crankshaft Position Sensor circuit a. I changed out the sensor, which was behind the starter. and my car still wont start. and now it still reads the same code, even after changing out the sensor..... Someone please help!!!!! lol
I also have had a push button start going straight to the ignition relay. been that way since 06. that's why bit still cranks. otherwise I don't think it would crank at all
The problem is not the sensor its self the problem is the actual wiring typically all codes with the wore "circuit" means wiring problem
CRANKSHAFT
POSITION SENSOR
CIRCUIT
P0335 24X signal
This diagnostic will detect
if there is no output from
the crankshaft position
sensor.
No output (~0 volts) from the
crankshaft position sensor.
5 Volts < Ignition Voltage < 17 Volts
Cam is transitioning
Sensed mass airflow >= 2.8984
No Cam Position Sensor DTC’s
No Airflow DTC’s
PCM state = READY or CRANK
CRANKSHAFT
POSITION SENSOR
CIRCUIT
P0335 24X signal
sensor.
No Airflow DTC’s
