Engine Swap Regulations In CA?
I understand the part of anything before 1975 you can swap away.
Also that anything above that year needs to have a the same year engine or newer. Along with all the emissions that came on that year and model.
So for say my "external" EGR.... would swapping a newer '01~'02 LS1 or newer LS6 engine be legal or not due to these having either an "internal" EGR or none at all?
Thanks for anyone who can clear this up for me
There is no internal EGR except for reversion. It is just "EGR".
Swap a LS6 and keep the EGR. Again block it off if you dont want to deal with it. Technically you are suppose to have it certified. However, you would be nuts to do that for 0.3 liters.
Be more specific with what you want to do.
Very few, if any Smog Check facilities can tell the difference between a virgin LS1 and a modified LSx assuming a mild cam. (Referees have been known to take off covers and measure lift)
There are only two reasons to go that route:
1) Its the LAW.
2) 402 inches of displacement at the nose of a miata will draw attention.
The risks and ethics are up to you.
Example:
1976 Camaro with LSx swap.
By the letter of the law the vehicle must have the PCM and Catalytic Convertors out of the doner TA/GTO/Vette/CTV and no internal enginer modifications. Moreover, some referees interpret the requiremnts to mandate the doner exhaust manifold be used.
This would be a big hastle and a high risk that it wont pass the first time. However, emissions would be <2% compared to new in '76.
Instead, the doner LSx is converted to a carburetor setup with a bigger cam and passes under the radar. Still cleaner than before, but not as clean as EFI.
Exhaust Gas Recirculation is dependent on the engine. If you swap a newer LSx and certify, then no EGR is needed.
now if you change to an LS2 with intake, some one might notice.. but they would have to know what to look for.. smog techs main concern is to look for any wires, vacuum lines, headers, air intakes, anything aftermarket.. and stock emissions stuff.. they arent looking at heads and blocks.. and no they wont pull block #'s
the CA rule to engine swaps, WITHOUT having to take your car to a smog reff is this:
you CAN NOT swap an older engine into a newer vehicle.. period
You CAN swap a new engine into a older vehicle, so long as the engine was offered in the same make, model and Generation and retain the newer engines emission and cat placement.
example: 1986 Camaro IROC.. only came in 5.0 with Mas air (TPI version).. the 1992 camaro had a 350 with speed density(TPI version).. you can legally swap this engine into the Iroc and NOT have to go to a ref, so long as you have the new emissions sticker in the engine bay, and the smog tech can verify this engine was legal in 1992 for make, model and generation.
Now if you were to swap and LS1 into a 1992 Camaro.. you would need to go to a ref because the generation has changed and was never offered.
so TECHNICALLY.. if you put an LS2 (with all its smog stuff and intake and all that) into a Camaro/Firebird.. yes you would need a smog ref because that motor was not offered in a 4thgen ever.
keep in mind.. when do, do a swap and you have to go to a ref.. they WILL check for the correct fuel tank, evap, placement of O2 sensors and stock cats(this is a big one)... block #'s intake #'s, fuel injector #'s, everything.
I know, because I have done and helped another person, swap 2 LSx swaps in different cars.. a 1993 RX7 and a 1989 Iroc. When you do pass the ref station, they will then issue a barcode, that will then be fixed to the inside of the driver door jam. So everytime you have to get a smog check, you must tell the tech to scan the bar code 1st then begin the test, because its then tested as the engine you swapped in, and not the car.
good luck
And this was in a old jeep (tj) if i remember correclty
in theory...
if you went to a ref with for instance an LS7 in 4th gen F-Body and of course it passes due to it being a factory GM engine. So you get a code on on the door jam... etc...
then after seeing the ref you swap that LS7 out for say a "402, 408, 427" and then go to a smog check...
when they scan the code, is it specifically for that LS7 engine or will they not know and not give a **** about that different cubbed engine in there?
basically.. do it once.. do it right.. leave it alone..
and yeah I forgot about the cam specs.. they do check for that.. also.. they have the same computer equipment as, lets say HPTuners, to check for anything you have done in the computer.. such as turning off the trouble codes for EGR, AIR.. they look at the timing tables and fuel maps.. compair them to stock..
its not an easy process.. so like i said.. do it once... and do it right.. we passed the thirdgen off the 1st time... the RX7 passed the 2nd time.. due to the CATS being placed 4" too far back of the stock length... crazy
Angel Side
you can only swap out the LS1 or a newer LS1 or LS2, LS6, LS7 without having any problems and not have to use the car's emission components and only the engine's - get's stamped and good to go
Devil Side
you can swap out the LS1 and replace it with any stock like 402, 408, 427 and go to a "dumb" smog check station and pass with flying colors
Finding hard info on what really passes a Calif smog test though is ... hard.
EO: D-278-1 View PDF
EO Date: 10/29/1997
Manufacturer Name: GM Motorsports
Device: 5.7L H.O. Performance Package
Device Type: Engine Modification/ Engine Change
Part_Number: Model_Specification: Modification_Allowed: Remarks:
1982-1987 GM Camaros/ Firebirds originally equipped with 5.0L or 5.7L engines It includes the following main components: ZZ4 5.7L enigne (part no. 24502609) which includes a new camshaft, pistons, cylinder heads, intake and exhaust manifolds, an electronic control unit, new dual catalyst exhaust system, and transmission shift kit. It does not utilize the use of an EGR valve or the carburetor heat stove. Exhibit A list additional parts included with the kit
Or you can just take it to get it smogged after the swap and hope they dont notice. if they dont you saved yourself a lot of hassle. If they do notice then you gotta do what you gotta do.
Or you can get an illigal smog
EO Date: 10/29/1997
far as swapping "LSX" engines into non-powered "LSX" vehicles what are the guidelines and restrictions for this swap?
...is it the same as a newer manufactured engine into a later model car type thing, as long as it meets all the emissions, pcm, etc. requirements?
for instance all these LS1 rx7 guys in CA running "legal" swaps after seeing a ref.... so it's allowed?
