CA Smog question
I'm trying to figure out how to get more power while still passing visual and smog. I thought about going P1SC or STS, but I know I'll need to get at least $5000 just in parts and by the time its installed and tuned I'm upwards of $7k and with 113,000 on my motor I figured I'd end up having to replace that shortly thereafter if I go boosted. So I figure LS6 conversion (essentially) is about my best bet if it will pass smog.
Thoughts?
I think it's a waste of money to do and LS6 conversion. There are much better choices out there.
ported heads 10.6:1CR, 222/224 .566/.568 114, LS6 intake, no egr, no a.i.r,
FLP headers, high flow cats, stock SLP cat back. 400rwhp 375 rwtq.
like you said.... get the sensors deleted and ask around for a cool smog shop.... i found one.
good luck.
Search "smog" and go through the thousand or so posts regarding smog in the last month, it's bound to be there.
I passed with a 224-230 on XER but thats on an LS2 bore. The guy who bought my Black TA with the same cam passed smog as well.
So it sounds like, with the right tune, a 224-228, Ls6 intake, and LS6 based heads I should be able to get through smog and visual.
As far as the heads go, can I get with stage 2 or will I need to keep it basically stock?
What about the heads, stick with CNC'd ls6's (the one on GMPartsdirect) or go up to stage II LS6 heads from an aftermarket company?
I think I want the 114 LSA anyway, I don't want it too lopey, but I hadn't thought about the total overlap.
if i had to do a H/C car again.... id get better heads ..... some AFR 205's....with
around a 11.2:1CR, and id go with somthing near a 224/228 .581/.581 112.
then do a 90/90FAST combo.... UD pulley, LT's, no cats, and a cut-out and you might
see 430rwhp.... then for smog time, just throw on some NEW cats., and at the worst case, have it detuned a little......
good luck guys!
good luck guys!
Yeah, I think the parameters were pass smog AND visual.
