is this guy asking to much???
Old Mar 4, 2016 | 06:51 PM
ChazWhiteZ28-'s Avatar
Default is this guy asking to much???
https://jonesboro.craigslist.org/cto/5476762181.html
this is a bare bones z28, cloth interior, manual windows, etc. seems a little on the high side.
what do you guys think?
Old Mar 4, 2016 | 06:56 PM
ULTIMATEORANGESS's Avatar
it looks clean. of course youd try to talk the seller down but if everything on it works that asking price imo isnt out of line.
it looks to be a non Ttop car and thats a killer for me.
Old Mar 4, 2016 | 07:01 PM
its a ttop. really?? i would think like 5k tops for it. idk...
Old Mar 4, 2016 | 07:14 PM
Z28 6spd's Avatar
I agree. Looks like a solid original car, assuming no rust or accidents. Actually a 6 speed no options car is pretty desirable to a lot of us.
I think it does have t tops. You can just make out the center strip in the front pic.
Old Mar 4, 2016 | 07:15 PM
justin455's Avatar
Douchebag On The Tree
Looks like a Ttop to me. I would offer $5k as a starting point.
Old Mar 4, 2016 | 07:22 PM
start at 5k and work up to? what 6 to 6500? and that would be a good price? assuming it has the usual scratches and wear thats associated with these cars? what should be checked?
the guy said the ac compressor makes a weird noise when turned all the way up to max. sound like a hard fix? he said the ac blows cold. and doesnt make a sound if its not on
Old Mar 4, 2016 | 08:02 PM
yes i just noticed it does have Ttops.
id pay mid to high 5s if it needs only minor or no repairs which i doubt.
anything major id just start deducting the sellers asking price from there.
Old Mar 4, 2016 | 08:05 PM
hmmm minor repairs would have to be expected, even though he said the ac noise was the only issue. i doubt he comes to mid fives. he was pretty firm on 6500 bones when i was talking to him earlier. we shall see...hopefully the ac noise issue is small.
Old Mar 4, 2016 | 08:12 PM
Mappinsj's Avatar
6500$ not bad. 115k is about maintenance time though
justin455's Avatar
I'd say anything under $6k, but it all depends on condition. Wave $5800 cash in his face and see if he wants you to walk away over $700.
Old Mar 4, 2016 | 08:33 PM
i think thats a fair offer if it needs no major repairs.
AC is a must for me and can be expensive to repair so id look closely to see exactly whats wrong.
Old Mar 4, 2016 | 10:01 PM
the ac works acording to him, just makes a weird noise when its on full blast, ill look at it.
ill wave 5800 bucks to see what happens. i can do all the repairs myself so that shouldnt be to bad.
Old Mar 4, 2016 | 10:54 PM
Firebrian's Avatar
Less things to break with no options. You don't have to worry about window motors failing and paying hundreds of dollars to fix them. That's a plus to me. Car is lighter with less options, hence lighter = faster. At this price range and mileage I wouldn't worry 1 bit about options. The value of the car is paint, interior, and drive train/mechanicals. If it runs nicely all around, that's all you need. A picture of the engine bay was not included. That's as important as any of them.
If the AC system is making noise and it's still on the original compressor, figure on a new one of those, maybe a pulley as well. A quality OEM compressor + drier/receiver/exp valve costs around $350-$375. If you buy a cheaper knockoff you can get out for $200-$250. The original compressors were ACDelco/Delphi. I usually figure if there's still an ink stamping on top of the receiver/drier, it's original. But, it's possible a fussy owner could have insisted on an OEM replacement that is also stamped.
Figure no matter what, you'll miss some items upon inspection and those will run you $500-$1,000 (fluids, filters, lights, tires(?), brakes(?), clutch(?), seals, shocks, pumps, bushings, speakers, exhaust/cats, etc.). There's a lot of potential items. It comes down to how well it was cared for and what items are coming up for replacement in the future). It's a big plus you can do all the work so your downside is only limited to buying parts. The instrument panel shows the car at idle (normal 50 psi oil pressure, normal voltage, temp gauge looks to be off the low peg, normal idle rpm, and showing 1/4 tank of gas). At least this is not the type of owner who keeps the gas on "E" to save $3 before selling it.
I would think a nicely running M6 with 115K miles would be worth in the $5,000-$6,000 range. It's a wide range where a lousy car for $5K is not worth the trouble. While an identical mileage car that is sweet, could be a bargain at $6K. Neither is usually the case though, but something in between. There are numerous current threads on what to check for on these cars. A recent one linked below.
https://ls1tech.com/forums/new-ls1-o...need-know.html
Don't forget to check all the key fluids (7), including clutch fluid. Ideally, they will be at normal levels and clean. Before you check, ask the owner when each was last changed.
Old Mar 5, 2016 | 09:02 PM
he sent me some pics, the engine bay is very dirty, the sail panel has the bubbling clear coat, and the front bumper has some serious scuffs that look like it wont be able to be buffed out, are these deal breakers??
Old Mar 6, 2016 | 07:44 AM
thoughts??
Old Mar 6, 2016 | 07:48 AM
madmike9396's Avatar
He likes to take the t-tops out and let his mullet flow
Old Mar 6, 2016 | 12:33 PM
went to look at it today, ended up not getting it. the bumper and fender were damaged as if someone hit it with something, the entire sail panel looked awful. would have to replace it, the entire had rips, and places that had shitty sew up jobs, the interior was missing some pieces, as well as cracked panels, and buttons missing, as well as severely stained carpet. it was going to need engine mounts soon, the engine was all over the place at idle. ac compressor did make a godawful noise. transmission was making a weird whining vibration. other small mechanical and cosmetic things. he wouldnt go lowe than 5800, an i couldnt see myself paying any more than 5k
Old Mar 6, 2016 | 12:45 PM
Mappinsj's Avatar
Wow what a **** stain car.
Old Mar 6, 2016 | 04:48 PM
is that sarcasm? lol. idk the guy didnt really seem to be very upfront from the start. he was really trying to sell the "ls1" aspect of it i think. he kept saying "oh, ive had this car and this car, but this camaro is so much faster". im sittin there think alright man, whatever you say.
Old Mar 6, 2016 | 04:52 PM
Mappinsj's Avatar
No that really is a **** stain
