Rims and tires question???
Old Oct 17, 2008 | 09:17 PM
Interlizer130's Avatar
Default Rims and tires question???
Will C5 corvette rims 17x8.5 with a +54mm offset fit on my 99 Ls1 Firebird Formula without rubbing with a Kumo Ecsta SPT 255/40ZR17 tires? I want to put these tires on the front.
Old Oct 17, 2008 | 10:11 PM
99Bluz28's Avatar
Lightbulb
No problem, but I would use a (stock height)245/45/17 or(a little tall than stock) 255/45/17 tires.
Old Oct 18, 2008 | 09:07 AM
My back tires are 295/30/r18 and I'm thinking the thickness in sidewall from the front and back tires is going to look wierd because the back's are going to be skinner than the fronts?
Old Oct 18, 2008 | 09:37 AM
Xsta Z 28's Avatar
Well unfortuantel'y to run a 17" and 18" combo on a F-Car, you are going to have to have the front side wall taller than the rear. The ABS system on the car needs the OD of the tires to be very close, or it will read tire speeds as different and fail during a panic stop.
Old Oct 18, 2008 | 10:11 AM
Well i had a 275/35/zr18 tires with a C5 18x9.5 with a +65mm offset on the front before but every time i took a sharp turn they would rub bad on the lower control arms. So thats why i wanted to go with somthing smaller in front but they dont offer anything in an 18 inch rim with a different offset. They only have the +54mm offset in the 17 inch rims for the C5 rims.Any help here?
Old Oct 18, 2008 | 08:48 PM
barnat's Avatar
Default C6 Zo6
Im running 4 front C6 ZO6 (18" by 9.5") on my 02 SS that are in the sales sect. with all 4 tires wrapped in 275/35/18s and they fit the car PERFECT!! and are pretty wide tires too!So whatever offset mine are,? is what you want!
http://s243.photobucket.com/albums/ff160/ebarnat/ss/
Old Oct 19, 2008 | 02:51 PM
I need to know what kind of offset i need for the fronts though? i looked up the C6 Zo6 wheels and they offer them in a couple different offsets.
Old Oct 19, 2008 | 03:41 PM
99Bluz28's Avatar
Lightbulb
For the front look for : +40 to +56 offset.
Or you could use a 1" hub spacers(1" maximum) up front with the +65 offset 18" x 9.5" wheels
Old Oct 20, 2008 | 05:25 PM
dont i need longer wheel studs for a spacer that big?
Old Oct 20, 2008 | 07:45 PM
99Bluz28's Avatar
Lightbulb
No, they bolt on to your factory studs, and they have studs built into the spacer, which your wheels bolt to.
Old Oct 20, 2008 | 09:26 PM
have you ever seen them on a f-body, is the rim gonna bulge way out and look stupid or will it look alright?
Old Oct 21, 2008 | 12:46 AM
99Bluz28's Avatar
I seen a few camaros with 17" x 9.5" with a +38 offset and the wheels/tires don't stick out. But, IMO I wouldn't use a wheel with less than a +38 offset(fender lip Issues).
Anyway with the 1" hub spacers your wheels(18" x 9.5", +65 offset) would effectively give you a +39.6 offset.
If you want you could just get longer ARP studs and use a 3/8" spacer, or 1/2" spacer which would give you a +55.5 offset with the 3/8" spacer and a +52 offset with the 1/2" spacer.
IMO, this would be the least expensive route to take. But make sure you get hub centric spacers.
All of these will work.
