18x10s WHAT TIRES????
well with the size being said is this a daily drive or a weekend cruiser? the BFG drag radials in the size above would be nice but not if it rains. a little more information please.
i also plan on running 18x10's in the rear but are you guys positive that you can run 305 nitto's on the rear??? i haven't heard seen or heard anyone have problems with low profiles on the rear since ive been researching on this forum the past 5 months your starting to scare me cuz i want to run 35s???![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Wheel Fitments
The numbers in the columns are as follows:
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 29510.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
how are you guys running 305's on 18x10s???
Wheel Fitments
Front and Rear
