Drag wheel size options
There is little you need to consider, I can build you a direct fit drag wheel setup. You'll be able to bolt on the front and rear drag wheels without modifications to your car or calipers.
If you don't care about having to do modifications to make the wheels fit, weld economy line wheels i.e. prostars/draglites are a very good choice. They are probably the next in line regarding performance benefits. Using them though would be like leaving about 50lbs on your car verses our wheels.
The next question is, Are you looking to Just bolt slicks or a Drag radial on and keep your Fronts or are you Looking for a complete package.
We offer a package with 2 15x10's with the correct backspacing and a direct fit wheel, As well as 2 15x4 that requires Minimal grinding on the front calipers to work. there is a few threads with the pictures so you can see what is needed. Our wheels were designed for Street and Strip usage, You can bolt our on and leave them on for awhile as opposed to many wheels that are Race only, or For Off Road use only.
you can check them out here on a few cars.
https://ls1tech.com/forums/wheels-ti...o-pricing.html
The price on my 15" package is 1140.00 shipped to you with Lugs.
