Help please 17x11 vs 18x10.5
For the life of me I can't come to a conclusion
. On if there is a major impact between the 2 performance wise. I'm pretty sure I know appearance wise I would want to go with the 18x10.5. Whats driving me insane
is... well, do I really need the 1/2 inch that I'm losing going with an inch larger in diameter?? I mean is the traction going to be that more significant? If I had the coin to drop on some CCW'S or Iforged for a custom 18x11. I wouldn't have posted this question and would have called it a day already but. Before I drive myself insane. Also to put an end to the madness, I thought I'd ask. The people that I know have the experience and knowledge to end this debate. I'm pretty sure that I will get better answers posting in this thread. Rather than in the appearance section? Because appearance wise I'm aure 18's would fill the wheel well diameter wise a little better
. I am also aware that 17x11 out back would look killer
. Thanks
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Wow!! Seems like every scenario that I have contrived is reality. I have simple mods on my car and. It's seems that even coming down from 20's(yeah I know) to 18's. In a wider width will Still give me traction problems. Will the 1/2 in the 17x11 be that much better though? I am lowered on Sportlines. This will also be my 3rd set of rims and I just want the next to be just right. To hold me off for a while till I can land, to me at least, the next level in rims.LOL
You're not going to be gaining traction from the additional width of the tire, its the height that you'll see the benefit. Tires on 17's have a taller sidewall than those on 18's (maintaining that they are 26" tall over all), the sidewall flexs as the tire grips, the taller the side wall the more the tire can flex and absorb the impact making it hook. The smaller the sidewall, the less you will hook due to less flex or absorption. Width of the wheel isn't an issue, this is why people can cut 1.5 60' on a 15x8 wheel. Anything more than that width wise is purely for looks.
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
IMO, get the 18s! ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
295/35/18s, and the 315/30/18s both will look good, and perform well on the 18 x 10.5s, and you have more tire options!
The tire construction itself will have a bigger influence on traction than whether your running 17s or 18s, 275s or 315s.
So get what looks best to you!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Mainly street, rarely track. This is great and is really helping out a bunch. I'll probably watch the thread out some more. Just in case anyone else adds some opinions or advice.
Thanks again
Thanks again
17x9.5, 17x11 for a bird with 275/315
17x9.5, 17x9.5 for a camaro with 275/285
Birds have a slightly wider quarter that makes the 315 look better then the Camaro. To make a 17x11/315 combo look good on a Camaro I think it would need the rear narrowed 1" on each side. But you'd probably have to mini-tub it to get that to fit... IMO
Dont know about that. I love my 335 Hoosiers , w/ 17x11 Zr1 wheels on my 1998 Z28. Lowered 1in. for now but I had them on my 1999 Z28 i used to have with sportlines and looked great. Just rolled the fender lip and a cut down the bump stop down. Just used a adustable panhard bar and had no probs. with fitment. I have some pics, but are low quality
EDIT: If you're spraying on the street, do the latter option. IMO.
