New Wheels!
Old Feb 25, 2009 | 11:33 PM
Vassago's Avatar
Default New Wheels!
I am thinking about getting these for my 01 Firebird Formula.
http://www.nfcperformance.com/msport...1_563_569.html
The stats are
SPECIFICATIONS:
Model: ADR M-SPORT
Bolt Pattern: 5x120
Offset: +35
Color: Hyper Black W/Polished Lip
Quantity: A Set Of 4
Condition: New
I know the bolt pattern is right but the offset falls lower then what this page says is required. https://ls1tech.com/forums/wheels-ti...must-read.html
Will these fit alright on a stock ride with say 265s? or 275s?
Thanks
Old Mar 16, 2009 | 06:50 PM
Pipelayaz's Avatar
I beleive these wheels require backing plates correct?
Old Mar 16, 2009 | 07:15 PM
Bones87's Avatar
Talk to KyleLS1, he has them and they look incredible. I was going to get them in black but decided they wouldn't look right for whatever reason.
If you're going to buy them, check on ebay you can find them for a steal normally. Also, check out the wheelmaker Stern, they offer a rim which is nearly identical to those and not as expensive (its model name is ST7).
eBay ADR MSports...
I can PM you a link to the Stern ST7s if you want, just let me know.
Old Mar 16, 2009 | 07:32 PM
Pipelayaz's Avatar
I appriciate the info Bones. I have a buddy who is willing to part with his for $600 w/bald tires. I'm just looking for more info before I make the purchase.
Old Mar 16, 2009 | 08:04 PM
Bones87's Avatar
Word! Sounds like a good deal.. Good luck man, can't wait to see them mounted...
Old Mar 16, 2009 | 08:16 PM
'00_Z's Avatar
Don't forget the hubcentric rings to center them up. There is a lot of debate as to whether the bolt pattern is safe but a lot of people run them.
Old Mar 16, 2009 | 08:34 PM
Pipelayaz's Avatar
Yeah thats where I am with it. I've seen several people already run them so they have to be safe to a degree. I shot Kylels1 a PM asking him about his setup.
Old Mar 17, 2009 | 08:57 AM
LS1W66's Avatar
Just wanted to give you guys a heads up that the 9.5" wheels wth the 35mm offset will be on the ragged edge of sticking out of the wheel well in front.
Heres a pic of my 18x8.5's with 35mm offset to show you how close it could be.
Consider that the wheels you want will be sticking out another 1/2" and you may have issues when the wheels are in full jounce.
Old Mar 17, 2009 | 11:12 AM
Pipelayaz's Avatar
Thanks, I'll have to check for that.
