Skinnies and grinding
A quick search should find the answers. I know the information is listed. Same goes with stud specifications you requested. This stud information would easily cross over to your application. You need about .100" between the wheel and component. Measure what clearance you need to make your wheel fit. I will suggest not to remove the retainer clip. I would highly suggest discussing your needs with the vendor who you purchased the products from.
Our Bogart wheels, you would have just bolted them on without interference issues. Obviously that's one wheel I can take out of the mix.
