Narrowed Rear With Fat Lipped Wheels
#41
i didn't read all of the posts, but i would recomend you not narrow the rear more than 1/2" per side.
i have an s60 that is shortened either 1" or 1.25" per side. i forget. and strano/konis.
i have rpm 505's 19x9.5 with narrow vredestein tires and it fits fine. it tucks the wheels quite a bit the way i like it it. no problems here.
with other wheels, you will have a problem unless you go 15's or 16's. and that will depend on the offset.
i have problems with 17x10.5 TTM wheels on sumos. i have a 1/4" spacer and had to cut my lca's since i didn't want to buy offset lca's. the inner fender is beat to **** with a fender roll. i'm not confident in launching hard on this setup because of the scare of rubbing/cutting on the lca's. i'm at the point where if these tires got deflated, i would be in some deep ****.
i did have the TTM wheels with a 1" adapter and it was fine for the most part i needed a fender roll. before the fender roll, i cut chunks out of my tires. this is all with an adjustable panhard.
plan this out hard or be prepared to buy $3k+ wheels or minitubbing. eventually i will have to mini tub to get wider tires on. using specs that are too close will put you where i'm at.
You mentioned you narrowed the rear 1" per side, meaning that if you run a 1" wheel spacer a wheel designed for a stock f-body then it will fit perfect. Thats just common sense.
Sorry if I'm sounding like a dick, but I'm planning on getting custom wheels built for a 4" narrowed rear. I just don't see why you are trying to put stock wheels on a narrowed rear and expect them to fit.
#42
I honestly don't understand what your trying to say. Narrowing the rear end has nothing to do with the width of a wheel. If a 17x11 will fit stock, it will fit on a narrowed rear end WITH THE CORRECT BACKSPACING. Smokedoutz has a set of 17x12s on his car and he mentioned that they fit without and beating. I'm planning on rolling my fender lips too, that way I don't have to worry about it.
ask SmokedOutZ28 what he has as options for wheels in the sub $2k range since you said you didn't want to spend $3k for wheels.
i don't have confidence in launching with a 1" adapter so don't go in this thinking that you can get back to stock wheel options by using a 2" adapter and feel safe.
#43
You realize 2 inches off each side (4 inches narrower..) would make the rear end the size of a regular Third Gen's rear right?
You sure as hell don't need to spend 5k to get custom wheels for a Third Gen, why the **** would you need to spend 5k to get custom wheels for a 4th gen?
Common. Sense. People. GOD.
#44
Are you retarded or something?
#45
There are wheels out there that won't cost too much for a custom offset. TT2s are an example, they will cost more than the regular TT2s, but not cost the price of a billet set of wheels.
But if I end up spending 5k on wheels, I'll be happy to post up pics for you
#47
Dude whats your problem? I don't want to run stock wheels, and I am not going to try to make them fit with a narrowed rear. I may run spacers for a little bit, but I can tell you that I will drive the car completely different.
#48
I understand where you are coming from, but I understand that I'm going to have to spend money to make it work. But I'd rather have something differeent, and I can get wheels that won't break the bank for now and spend more down the road.
#49
Well I found a set of wheels that I like that I can order directly from summit, but the price seems kind of out of line. I have found the wheels from other places online for $100 a wheel less, but can't find them in the correct offset.
http://www.summitracing.com/parts/ARE-CL2057116560/
http://www.summitracing.com/parts/ARE-CL2057956170/
And I know that they are 2 different bolt patterns, thats a different story. But it looks like these will be perfect as far as fit goes, I'd still really like to get 18s especially since I will be spending over $1400 just for the wheels. And I would more than likely repaint the centers of the wheels to give them a custom touch.
So if anyone has suggestions for 18s that will be roughly the same price post them up or PM me a link, $360 a wheel for 17s, I don't know if I can justify that
#50
#53
3" narrowed per side. Greg weld fronts. Summit Stars 15x10 with 4.5'' of backspacing running 275/60/15 MT's. Had to run a quarter inch spacer due to extreme caliper grinding. Still on stock Suspension at the moment. Will be lowering soon. I too am looking for a street trim setup. Seems like torque thrust II's are the most reasonable option.
