wheel spacers
Old Mar 21, 2009 | 01:41 AM
2001pewterbird's Avatar
Default wheel spacers
i have an 01 v6 bird and i absolutely hate how far inside the rear quarters the tires(235's) sit. i dont want to buy new wheels and tires right now so i was thinkin about runnin 1"-1.5" spacers but i dont know top much about it. would this be ok to do?
Old Mar 21, 2009 | 01:45 AM
Donohue96M6Z28's Avatar
It is ok to do as long as you get the adapter style spacers. But look at the inside of your wheels and make sure that in the between the lug holes, you'll have room for the spacer studs. Some wheels dont have room. I've never come across a 16x8 wheel that would allow this style spacer.
Old Mar 21, 2009 | 01:51 AM
ok ill have to check it out tomorrow. thanks =)
Old Mar 21, 2009 | 01:58 AM
99Bluz28's Avatar
Lightbulb
This should help!
Factory 16" x 8" with 1" H&R hub spacers.
https://ls1tech.com/forums/western-c...cers-sale.html
Old Mar 21, 2009 | 01:59 AM
[QUOTE=99Bluz28;11284090]This should help!
Factory 16" x 8" with 1" H&R hub spacers (Which I have for sale).
pm sent.
Old Mar 21, 2009 | 08:53 AM
greatskiiiier's Avatar
the adapter style spacers are suppose to work great, i jsut bought some 1.5 spacers cuz i got a 3rd gen 12 bolt, 6068 (or something like that) aluminum with grade 8 studs
should have order 1.75s cuz they're rubbing the bump stop, once i get home from college ill be taking the angle grinder to those bitches
Old Mar 25, 2009 | 09:18 PM
slick1851's Avatar
Dont cheap out on the spacers, I know its a old thread but just a FYI for others that look at this.
Old Mar 27, 2009 | 12:47 AM
Eiyse98ls1's Avatar
i have somewhat of the same design as 99bluz28. ive been running them for a while now without any issues. actually orignal studs had to be cut to get rim to mount flush.. also the ones above are hub-centric mines arent..
Old Mar 27, 2009 | 06:00 AM
RiceEaterZ's Avatar
ive got a 02 z, with 17x11 zr1's out back with 315 meats....mechanic said they are rubbing the bumpstop and i need spacers....assistance??? brand...company....I just bought those SLP jounce spacers, will that help?? my tires are bald and I want to get squared away before I put on new dr's or street hipo just to fk em up. just pound it out with a bfh? roll my fenders??
Old Mar 27, 2009 | 06:45 PM
Eiyse98ls1's Avatar
Originally Posted by RiceEaterZ
ive got a 02 z, with 17x11 zr1's out back with 315 meats....mechanic said they are rubbing the bumpstop and i need spacers....assistance??? brand...company....I just bought those SLP jounce spacers, will that help?? my tires are bald and I want to get squared away before I put on new dr's or street hipo just to fk em up. just pound it out with a bfh? get someone to roll my fenders??
not sure how much of a spacer your going to need but what you can do is use washers in between rim and hub to get the clearance you need then look for that size spacer. i got spacer adapter which more then likely you wont need. also the bigger the spacer will move the heel/tire close to fender. you should also watch for that. you may end up having to roll fenders. best bet is to search here to find out what others have done.
as for companys theres several just do a search.
hope that helps
check this out: https://ls1tech.com/forums/wheels-ti...must-read.html
Old Mar 27, 2009 | 08:24 PM
99Bluz28's Avatar
Lightbulb
Sounds like it's time for a little Cut/grind on the bump stop assembly.
Old Mar 27, 2009 | 08:49 PM
99Bluz28's Avatar
Lightbulb
If you look at the bump stop Assembly from above you'll be able to clearly see where you need to cut.
Cut/grind on the bump stop within the Red area.
Old Mar 28, 2009 | 12:28 AM
RiceEaterZ's Avatar
Cool Thanks, Ill remove that corner once I grab A Grinder, I just dropped a handful today at sears for a bigass box of tools. Supposedly these slp spacers are supposed to permit the use of 17's on our cars without rubbing, so I'm gonna put em' on since I already payed for em', it makes them sit an inch or more lower, then I'm gonna Roll my fenders and finish up with a pinch of BFH
