Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 05-18-2005, 06:11 PM
  #221
Dogmeat's Avatar
ok I know these are pretty boneheaded questions, but:
a 275/35/18 size tire that the manufacturer says requires a minimum rim width of 9.0" ....it would be a bad idea to try to fit this tire on an 18x7.5" rim, right?
With that said, if I have a stock 00' Trans Am (non WS6) and wanna run a 275/35/18 tire on an 18x9 rim (38mm offset) I shouldn't have any fitting or rubbing troubles whatsoever would I?
sorry to beat a dead horse over and over but I just wanna make sure I get this stuff to fit since it's costing me a few grand
Dogmeat is offline
Old 05-19-2005, 07:35 AM
  #222
Xsta Z 28's Avatar
That is a very bad idea . . .
That will fit great.
One always wants to get the wheels right the first time.
Xsta Z 28 is offline
Old 05-21-2005, 03:35 AM
  #223
SSmokeDaGT's Avatar
I know All you all heard this already and I read this thread over and over. I just need a straight forward answer. I have a 2000 SS and I want to buy black Z06 motorsports with 17x9.5 +54mm offset in the FRONT and 18x10.5 +58mm in the REAR.. WILL THESE FIT? Any issues and what TIRES do ya'll recommend? Thanks in Advance ya'll
SSmokeDaGT is offline
Old 05-22-2005, 08:50 AM
  #224
Xsta Z 28's Avatar
Fronts 275/40ZR17 and will fit fine.
Rear 295/35ZR18 will fit, I used to run that size. May need to do the BFH mod to the inner wheel well, or run a spacer with longer studs.
Old 05-22-2005, 02:39 PM
  #225
SSmokeDaGT's Avatar
Whats better spacers with longer studs or BFH mod? Money is not an issue but how much does spacers and longer studs cost?
Old 05-23-2005, 06:21 PM
  #226
cthomas's Avatar
I'm wanting to order some 17x9 inch wheels with a 35 mm offset. The company says they will fit fine, but recommend a 245/45/17 tire. I want to run a 275/40/17, I know that tire will fit on a 9" wheel just fine, but my question is will I have any rubbing issues with a 275 width on 17x9" wheel with a 35mm offset? By the way i'm putting them on a '98 Z28, thanks for any info.
Also would a 275/45/17 look better than the 275/40/17 being about an inch taller, and would it work ok with out rubbing? I have a hand held programer to adjust the speedo.
cthomas is offline
Old 05-24-2005, 06:06 AM
  #227
Eiyse98ls1's Avatar
im running stock y2ks 18x 9.5 all around. the rears i used a one inch spacer and had to have the fender lips rolled and everythings been fine. now i want to get the same y2k's with 18x10.5 out back and still have the stance and rims out back near the same location. will the y2k's 18x10.5 with the 58mm put me there?
that should be the same as the zr1 or z06 rims with the 10.5 right?
pics in my sig to show what im talking about
Eiyse98ls1 is offline
Old 05-24-2005, 08:01 AM
  #228
Xsta Z 28's Avatar
A 35 mm offset will be close . . granted it is on a 9" wheel, so it should be located within the wheel well similarly to my 38 mm offset 9.5" wide wheels.
Tires, run the OEM size 275/40ZR17. Absolutely no reason to run a taller tire. As for rubbing depends, if you are lowered the chances are there, and a taller tire will just make it worse.
Old 05-24-2005, 08:09 AM
  #229
Xsta Z 28's Avatar
With the 58 mm offset 10.5" wide wheels you more than likely will want to run a spacer for maximum "appearance". 1/2" most likely work well for you. Since you are runninga 1" spacer, I assume you have upgraded your wheel studs.
  #230
Xsta Z 28's Avatar
For maximum appearance reasons I'd run a spacer.
Old 05-24-2005, 05:47 PM
  #231
Eiyse98ls1's Avatar
actually i havent. i want to get rid off the spacer compleatly since i heard lots of stories about the spacers and at high spped dont want anything happenng.
so without the 1/2 spacer in will be 1/2 in more then where im at now? just dont want to have a spacer if not nesccary.
the 1inch spacer is a adapter btw.
Old 05-26-2005, 03:07 AM
  #232
Eiyse98ls1's Avatar
other then maximum apperance will they fit with any problems? my fender wheels have been rolled so i just want to make sure they will fit properly.also i am lowered with hypercoil springs. you stated in the 1st post 10.5 for rear would be a max of 50mm which puts me 8mm off.
thanks
Old 05-29-2005, 10:37 AM
  #233
quiet_storm98's Avatar
Lightbulb what about these
ok i just bought some c6 replicas and both the places that were selling them said they will fit fine...they are 18x9.5 but they have a 58mm offset so will they fit???
quiet_storm98 is offline
Old 05-31-2005, 08:32 AM
  #234
Xsta Z 28's Avatar
A spacer to run 58 mm offset wheels is not required, but you will need to do some inner wheel well mods.
Old 05-31-2005, 08:35 AM
  #235
Xsta Z 28's Avatar
thanks
Just so you know, on the F-Car, the larger the offset numerically the further the wheel moves INWARD, so the small numerical offset moves the wheel OUTWARD.
A 58 mm offset wheel will be tucked in and the tire could contact the wheel well (undercoated part closest the the back seat).
  #236
Xsta Z 28's Avatar
They will fit, but be tucked in a bit.
Old 05-31-2005, 07:47 PM
  #237
97PredatorTA's Avatar
All right, I read through about six pages and kept getting more and more confused. I'm starting to get how it all works, but you guys really seem to know what your talking about so I'll just ask my question and get it over with. Sorry if someone already asked.
I saw before that someone said they had 17x11 ZR1's in the rear with 315's, and I think +50 offset or around there, and you guys said that would work with some BFH. I found a set of ZR1's, 17x11 and +36.5 offset with 315/35/ZR17 tires, same thing but different offset. The offset is what I'm still confused on. Is +36.5 better than +50? Which on of these two will have a better chance of rubbing? Thanks.
97PredatorTA is offline
Old 06-01-2005, 07:34 AM
  #238
Xsta Z 28's Avatar
I assume you have a TA, so you have more options since the wheel well of a TA is bigger (quarter flares out more than a Camaro). So with that said the 36 to 38 mm offset 17" x 11" wheel does fit, although puts the tire very close to the quarter lip. I prefer the 50 mm offset, but that may (typically does) require some massaging of the inner wheel well. The 50 mm offset wheel is easier to resell, since it fits the Camaro. So hopefully I got you covered.
Old 06-01-2005, 02:15 PM
  #239
So +36 offset will set the wheel closer to the rear quarter panel, and +50 offset will set it closer to the inside wheel well. If I understand that correctly, I think I'm finally starting to figure out this wheel stuff. Thanks for the help.
Now will this offset put it outside the rear quarter? Like sticking out past the fender a little? Because I don't want that either.
Old 06-09-2005, 09:55 AM
  #240
camaronut502's Avatar
I have a 2000 t/a with stock ride hight. I would like to run either the nitto 555R 305/35/zr18 or the 315/35/R17 on the back. What are my best choices among the common wheels out their? im just not that sure about rolliing lips and MFH mods, lol. So if thiers a wheel/offset that would work fine please let me know. thanks guys for the info.
Matt
camaronut502 is offline
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
