what size spacer?
Old Feb 24, 2010 | 02:00 PM
01SS99red's Avatar
Default what size spacer?
I have a set of prostars and was wondering what size spacer are used for the front 4 in. rim and what I should use on the back 15 by 10. I was going to try a 5/16 on both front and rear just want to check and see if these will work.
Old Feb 24, 2010 | 04:27 PM
01SS99red's Avatar
no one has any input on this?
Old Feb 25, 2010 | 08:53 PM
bluebird00's Avatar
im running a 5/16 on the front of my draglites but with a 7.5bs..
Old Feb 28, 2010 | 12:27 AM
01SS99red's Avatar
are they skinnies?
Old Feb 28, 2010 | 08:57 AM
MikeG's Avatar
I don't think they will clear on a 15x4" rim. A 15x3.5 will clear with a 5/16" spacer, but I've heard that yours will need a bigger spacer. This will make the wheels stick out even further though, and you'll risk damaging your front fenders if you come down from a hard launch.
You've got some grinding ahead of you if you want to run those wheels.
Old Feb 28, 2010 | 12:53 PM
01SS99red's Avatar
Im pretty sure the rim is a 3.5 by 15 so should i just go with the 5/16
Old Feb 28, 2010 | 01:45 PM
MikeG's Avatar
Ok, well you could have saved me some typing and said 3.5 instead of 4 in the first place! Those will fit fine with the spacer.
Old Feb 28, 2010 | 02:24 PM
01SS99red's Avatar
sorry about that. thanks for the info
