Clearance/fitment question
However, don't give up!! If the price is good enough on the wheels, you could always buy them, and send them back to CCW, and have the shells changed to give you the offset that you need. As far as I know, the expensive part of the wheel is the center....
front- 7 1/8" BS, 10 1/8" useable width, 1/2" taken off each side for tire bead.
rear- 7 7/8" BS, 10 1/8" useable width, 1/2" taken off each side for tire bead.
those numbers calculate to front: ~38-39mm rear: ~58mm
it seems the front should fit okay, but i'm not positive on the rear.
