Front TT2's rubbing 17x9.5 HELP
Like the title says, my front TT2's rub on the black plastic on the inside of the wheel wells when the wheels are turned. The right one even catches the bottom corner of the front bumper. It's drivable, but I'd just rather not be rubbing at all. They are 17x9.5's, with Nitto 275/40-17 tires. Anyone with any suggestions? Not sure on the backspacing, I bought them used
Thanks for the help guys, just went out to look for the offset, couldn't figure it out from the markings, will post pictures in a few minutes after my camera battery charges.
I'm at stock ride height, not sure on the alignment specs (I know, not much help). I haven't gotten an adjustment since I bought the car 2 years ago, and it was bone stock. Stock alignment if there is such a thing?
I don't see anything in the photos that's tell the wheel offset.
IMO, if its been at least 2yrs since your car has had a front-end alignment, take it in and get it re-aligned. Have then set it with less +caster (+5 or less), or less then it currently has, and a little - camber (-.1 to-.5) if possible.
You don't really need any negative camber, but it's good for handling.
