pro star help please
Old Aug 8, 2010 | 10:36 AM
slo98z28's Avatar
Default pro star help please
i am planning on putting front prostars on my 1998 camaro what do i need to do to clear brakes guys thanks need halp asap
Old Aug 8, 2010 | 10:49 AM
blk/slvr02ss's Avatar
A lot of grinding down the caliper and it sucks.
Old Aug 8, 2010 | 11:02 AM
slo98z28's Avatar
ive read that i done it on my lightning it was a pita like 1.5 per side in rear sux for sure
Old Aug 8, 2010 | 11:06 AM
The fronts took me all day and the back only 20 min a side.
Old Aug 8, 2010 | 02:10 PM
BlackDuk98's Avatar
Don't dick around grinding the fronts. Get longer wheel studs, and a 5/16" spacer and you can leave the fronts alone. Quicker, easier, safer.
mark jr.
Old Aug 8, 2010 | 02:35 PM
ghostbird's Avatar
spacers work ive got em on mine
Old Aug 8, 2010 | 02:37 PM
Long studs and thick spacers are not a good idea.They can break off very easy.
Old Aug 8, 2010 | 03:11 PM
PowerShift408's Avatar
I ran longer studs with a 7/16'' spacer on mine with zero problems. There is nothing unsafe about it.
Old Aug 8, 2010 | 03:26 PM
1baaadz28's Avatar
I wouldnt use longer studs and a spacer on back cause of tire spin, but the front seems it would ok!
Old Aug 8, 2010 | 06:58 PM
slo98z28's Avatar
ok so i need 5/16 spacer or 7/16s and where do i get studs from maybe a part number thanks in advance
Old Aug 8, 2010 | 09:18 PM
BlackDuk98's Avatar
Using the spacer on the front is safe. I am running a 5/16" spacer and 3" or 3.5" (cannot remember) ARP moly metric studs. If you look in a Summit mag, they have them listed in the gears and axles section and they are listed as being used for firebird / camaro. These are press in ones, not screw in ones. As others have said, do not use spacers on the back.
mark jr.
Old Aug 8, 2010 | 09:25 PM
http://www.jegs.com/i/ARP/070/100-7708/10002/-1
http://www.jegs.com/i/ARP/070/100-7713/10002/-1
First is for the 2.5'' version, second is for 3.25'' version. The 2.5'' should do it. I run the 3.25'' for NHRA rules.
Old Aug 10, 2010 | 09:34 PM
Black94Z28's Avatar
you get those on yet?
Old Aug 11, 2010 | 10:05 AM
Packy's Avatar
I have a either a 1/4 or 5/16 spacer and 2.5" wheel studs here. I can't remember the size because it came with the wheels when I bought them.
