C5 CCW's on 4th gen fbody?
So I'm looking into buying some CCW's (SP500) from a guy but he has them on a C5 Z06 Corvette, so I'm a little iffy if they'll fit on my 2002 WS.6? I know the bolt pattern should be the same but I'm not sure if the offset will be an issue here. The wheels are 19x10 and 19x11.5... I will roll my fenders and will bang up the inside a little bit more but I really don't wanna use spacers.
What do you guys think?
1 Post
I say get em if you can, try em out on your car and look at the options as far as what it would rake for em to fit, if there is no option to get em to fit, sale em to another Vette owner and try to make a lil profit off of them.
Call John or Chip at CCW - ccwheel.com.
They are great people. I just bought my second set of wheels from them.
I'm selling my Big Street Classics from my C5 and it would be interesting to know if they will fit an F-body. My new wheels are SP500's. 18x10 and 19x13 to run 275x35 and 345x30 tires.
Wheels and tires only have 2500 miles and are wrapped in nitto invo tires and all for 3 g's, good deal or no?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
As a couple of people have already said, call CCW and ask them. If the offsets aren't right, BUT the price is REALLY right, buy them anyway, send them to CCW, and they can put different front and rear "shells" on the centers that will give you the offset you need.
This is the beauty of a 3 pc. wheel. The center is the expensive part of the wheel, while the shells are relatively inexpensive to change.
They will bolt right up but suffer the sunken in look like most of the OEM C5 wheels do. Guess its a matter of preference and what you can live with . The OEM 17x9 SS wheels have a 50 mm offset . From that you can use a offset calculator and compare the C5 wheels you wanna buy. It will tell you exactly where the rim will sit in the wheel well compared to the stock wheels .
If you know the offsets of the C5 wheels your buying this calculator should allow you to figure out any question you may have ....and decide on an appropriate spacer if need be .
http://www.1010tires.com/wheeloffsetcalculator.asp
