any one run 345 40 17 on 11" rims ( pic ) ?
sorry to bring up an old thread.... but do you think it would be possible to fit those tires on a 9" wide wheel? I know if it was a typical 26" diameter tire it def wouldnt work but I am wondering if with that extra 2" of sidewall if it would be flexible enough to fit...
the other tire i was considering for the back is the MT et-street radial 2 in 295/45/17. the diameter is good at 27.2" but ive seen pictures and it always looks like they run narrow for their size. im just going by pictures though so its hard to tell.
well i guess since i didnt get a response that its a dumb idea lol. i do see a lotta people putting 315/35 tires on 9" rims so i figure even though the 345 is an inch wider its got 2" more sidewall so its gotta be more flexible. i think i might just give it a shot and see how it works anyways. the tires are only $184 each so i guess i can always return them or re-sell them to someone with wider wheels if they dont fit on my 17x9s.
#32
I have 335 Hoosier A6's mounted on 17x11's and they do have some bulge to them, I use them for autox and the only reason I have that wide is that they were free. Marking and measuring the contact patch vs the 315's I have mounted on my front 17x11's during the last autox and the effective patch on the ground is about the same, 12". If I were to put 345's on something it would be at the very minimum 12" so that I was actually getting use out of the extra width. Otherwise, you might as well run 315's on 11's IMO.
That being said, with 50mm offset on my race 17x11's, a 5/16" spacer and some BFH mods, the 335's clear fine for regular driving, but after an autox the tires still rub on the inside where 315's on the rear with no spacers did not.
