New WELD RTS on the SS
Old Jan 29, 2011 | 12:46 PM
Chrishbsbll's Avatar
Default New WELD RTS on the SS
I just put the new weld RTS 15 x 4 and 15 x 10 on my car and my "brake" and "ABS INOP" lights come on just cruising down the road. Does this happen to anyone else with big and littles. If so, How do I go about fixing it?
Old Jan 29, 2011 | 12:51 PM
Old Jan 29, 2011 | 01:00 PM
Slowv696's Avatar
looks awesome. I cant say that i had that problem when i put my bigs and littles on tho.
Old Jan 29, 2011 | 01:42 PM
PokeyGTO's Avatar
Those looks great! Nice choice
Old Jan 29, 2011 | 01:46 PM
01SuperSport's Avatar
OMG
Old Jan 29, 2011 | 01:54 PM
3.8redbird's Avatar
putting pictures in this case was a BAD idea lol.
not gonna get any help just a lot of drooling.
nice setup
Old Jan 29, 2011 | 02:00 PM
chon79's Avatar
28s in the rear? That might be why. or the skinnies. I know one of those can cause the light.
Old Jan 29, 2011 | 02:52 PM
94 Camaro Z28's Avatar
ABS will go off if the tires are 10% different in diameter from front to back. Nothing much (besides an ABS delete) you can do about it. It'll go off again when you put your street tires back on.
By the way, great looking setup. How much did those wheels run you? And did you have to shave the calipers?
Old Jan 29, 2011 | 05:13 PM
99LSS1's Avatar
That looks BaddAss!!! Gos I wish I could afford to get a set of those. More than likely the tire size difference is your problem. You need to program the bigger tire size into your PCM.
Old Jan 29, 2011 | 05:17 PM
J-Train's Avatar
The bigger tire size is not the problem, its the difference in size from front to back. Mine did the same thing with a 28" rear and 26" front. There is no easy fix for it. Remove bulbs from cluster (Not easy they are soldered in) tape over lights, about your two easy options. I dont think there is a way to program the lights out through your PCM, its a seperate system.
Old Jan 29, 2011 | 05:43 PM
mr_biscuitz's Avatar
Very true ^^^^^^^
Old Jan 29, 2011 | 06:05 PM
MYSTIC-1SC's Avatar
very nice.
Old Jan 29, 2011 | 06:10 PM
I am running 325/50/15s in the rear. I was thinking that the change in size from front to rear had something to do with it. I just wanted to see if this was a common occurence. The wheels ran about $1G (from summit racing) and got bout $40 in shank lugs. All 4 tires ran $580 plus shipping. And NO they clear the calibers perfect!!!!! No shaving AT ALL!!! Although to get a 325 tire to fit I did have to heat up the inner fenders and beat them in with a large hammer!
Old Jan 29, 2011 | 06:53 PM
PRAY HRD's Avatar
Those look Awesome!! Pull the bulbs and forget about it! LOL
Old Jan 29, 2011 | 11:06 PM
SweeTbone's Avatar
Nothing really you can do. The light will go away every time you shut off on the car, but both will come back on after you hit the brakes for the first time after starting up and driving. No big deal though. Unless it's really bugging the **** out of you, just leave the lights alone. I didn't tape over mine or anything, you just get used to it. Nice looking setup BTW.
Old Jan 30, 2011 | 06:27 AM
BOBS99SS's Avatar
Captain Double Post
The first car I love with color centers on a drag setup,nice work man,looks great,
Old Jan 31, 2011 | 10:31 AM
LS1RedZ's Avatar
Those black centers look ****** awesome on your car!! Nice car and wheel choice!
Old Jan 31, 2011 | 01:59 PM
MeanGreen's Avatar
I know this is not what you were looking for but do you have any more pictures of your car with those wheels? They look freaking awsome!
Old Jan 31, 2011 | 02:58 PM
bestlude's Avatar
Nice and beefy
Old Feb 2, 2011 | 10:54 PM
Yeah I have to get the car cleaned up this weekend and I will post some more pics on the ground outside
