325/50-15's MT's, How do they fit?
Old 03-26-2011, 08:09 PM
nwalton29's Avatar
Default 325/50-15's MT's, How do they fit?
Planning on buying me a set of DR's. How's the fitment. Not scared to use hammer, If that's all I need.
Old 03-27-2011, 01:27 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I think the bumpstops have to be cut off
Old 03-27-2011, 10:46 AM
SweeTbone's Avatar
I still have my bumpstops on. Hammer is a must. **** is still tight. Adjustable LCAs and Panhard are not required from what I have read, but I have both and it's a lot easier to make them fit. I did it with just a hammer, an air hammer that is.
Old 03-27-2011, 01:21 PM
nwalton29's Avatar
I like it, I believe I'll go that route.
Old 03-27-2011, 03:00 PM
608kZ28's Avatar
damn! think i just jizzed in my pants
Old 03-29-2011, 06:05 PM
spcearle's Avatar
I'm deff gonna have to go that route to...my new 275s aren't cutting it after running 315 street tires
Old 03-29-2011, 06:13 PM
uphigh07's Avatar
there is a black ss camaro with weld rts that just put them on his car also, i have seen many with this size, just BFH
Old 03-29-2011, 06:14 PM
uphigh07's Avatar
very nice looking car makes me kick my self for sellin the 02 maple red ta i had that was a roller with 14tho miles on it a little over a year back
Old 03-29-2011, 06:16 PM
ABA383's Avatar
Like said above, its easier to accomplish with adjustable suspension parts. I kept my bump stops, BFH'd the lower front of the inside of the wheel well, and rolled the fender lips with an Eastwood fender roller tool. They look great, but I already told the new owner that I'd go with an M&H or Hoosier version as the M/Ts are VERY heavy. The M&H and Hoosiers are much lighter options.
--Alan
Old 03-29-2011, 06:58 PM
NOSJNKY's Avatar
Much easier with adj. LCAs and panhard and of a BFH. I switched from MTs to Hoosiers and they are much lighter . Although the 60' stayed the same(1.29-1.31) on a prepped track, it does hook ALOT better on a unprepped track. These pics are after I narrowed the rear but the fitment was the same before.
Old 03-30-2011, 01:12 PM
GT_EATR's Avatar
I have a set of 15x10 with a 7.5 BS for my 98 Z28..Did you have to grind your calipers for the wheels to fit?? Just wondering if i should get drag brakes or will grinding the calipers hurt my stopping power? I've heard pros and cons about the grinding mod ...
Old 03-30-2011, 07:56 PM
nwalton29's Avatar
I run 15 x 10 weld pro stars. 7.5 bs. I ground stock calipers and use a 5/16 spacer.
Old 04-02-2011, 08:05 AM
AlteredChevy's Avatar
How much is your rear end narrowed? Also what is the rim size and backspace? Thanks
Kevin
Old 04-03-2011, 04:45 PM
25thhawk's Avatar
Are those hoosier radials in the pinks picture? They are wrinkled pretty good for a drag radial
Old 04-18-2011, 01:20 AM
uphigh07's Avatar
+1 on that^^^^^
Old 06-02-2013, 11:58 PM
Br1_ss's Avatar
FUUCK YEAH!!! Good thing I looked these up before getting 315's!!!
Old 06-04-2013, 06:45 PM
Mr. Trick's Avatar
Sorry its not the best picture to show off the width.
[/QUOTE]
Like said above adj panhard bar and LCA's make it a lot easier. I had to beat the crap out of the inner wheel well toward the front and roll the fender lips, but the car still has bumpstops and has some wiggle room left. Its rubs occasionally getting in and out of my drive way if I don't go in at the right angle.
Old 06-04-2013, 06:55 PM
blackls1ta00's Avatar
bfh for sure
Attached Thumbnails 325/50-15's MT's, How do they fit?-0811121247a_0001_0001-6-.jpg
Quick Reply: 325/50-15's MT's, How do they fit?
