Old May 27, 2016, 02:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Removing Rear Wheel Studs?
Old May 13, 2011 | 06:18 PM
Counted Out's Avatar
Default Removing Rear Wheel Studs?
What do I have to remove to be able to remove the rear wheel studs? They are all loose, but there is no way they are going out the back without something being removed.
Old May 13, 2011 | 09:23 PM
hawiianpwr's Avatar
Take a grinder and cut them in half. And putting the new ones in I cut a small sliver of the head off so it would just make it passed the sensor.
Old May 13, 2011 | 09:40 PM
MadIceV8's Avatar
Customizing Director
They should clear that ABS reluctor wheel. Just get a nice even and solid shot at the stud. I know I've replaced them before with the entire brake assembly still on the car.
Old May 14, 2011 | 07:19 PM
These ones are so bent/damaged they aren't coming out straight. But I don't see how it would be possible to put in new ones without removing the ring.
Old May 15, 2011 | 12:17 PM
tsench's Avatar
buy a new wheel bearing they come with all the stud
Old May 15, 2011 | 02:36 PM
808z28camaro's Avatar
X2!! Easiest way, not that expensive. you will probably need new bearings anyway/ eventually in the near future. being that 4th gens are considered older cars now.
Old May 15, 2011 | 05:55 PM
Do you guys mean a new hub? They're $270 on Rock Auto. :/
Old May 15, 2011 | 06:01 PM
I found them cheaper, but I can't find one that has that ABS/Traction Control ring on it. :/
Old May 16, 2011 | 06:25 PM
Is that ring for the traction control or ABS?
Old Aug 2, 2011 | 09:20 PM
fastcars95's Avatar
How did you end up changing them. I'm in the same boat. I need to put a set of longer ARP studs in. I dont want to pull the axles to change the studs.
Old Aug 2, 2011 | 10:35 PM
DopeFedZ's Avatar
http://www.youtube.com/watch?v=GkZqdiq5bxA
Old Aug 5, 2011 | 09:53 PM
I had to pull the axle, have the ABS ring (I think) pressed off, the new studs installed, then the ring was pressed back on. Taking the axle out is simple, and a local machine shop pressed in the new studs for $25 - well worth it.
Old Aug 6, 2011 | 12:43 AM
flippincamaro's Avatar
Glad you got it worked out, As for the guys saying new hub, It is for the rear, The front is what has replaceable hubs, Rear is axles,
Old Aug 6, 2011 | 12:48 PM
fastcars95's Avatar
The toothed ring looks smaller in the video then the one on my car.
