Question about lowering on 11 rears
You can, I've got 17x11 w/ Nitto NT555 315's...I have springs, heater hose mod for the lowering aspect. It took a lot of hammering and getting adj. LCA's also helped free up some room. An adj. panhard rod is also needed.
like ECU_Pirate said yes you can.
im lowered 1.25" on strano springs and have no rubbing issues.
just make sure that if you lower your car to get an adjustable pan har bar to center the rear end.
Mine is way lowered on 17x11's. It took was some BFH in the wheel well in a couple spots and making sure the rearend is centered with an adjustable panhard bar. edit.. also forgot I rolled the fenders too.
I lowered mine and I have 17x11 with a 315 rear. Its not a problem, I did have some rubbing up front on the inside fender well, so I did ad a 5/16 spacer. This really made the car look even better. In my opinion any way. Either way it will fit fine.
Edit: In addition to needing to roll my fenders now...I had to get the BFH out again and pound on the fender wells more. Haha
