315/35/17 q's before i order
well im running:
17x11 zr1's in the back with the 50mm offset
96 z/28
stock 10 bolt at the moment, swapping to my 99 10 bolt in the next few months
umi non adjust panhard, swapping to my double adj panhard in the next few months
stock lca's, swapping to my adj ones in the next few months
stock rear ride height, dont plan on dropping the rear as of now
i plan on ordering nitto 555r 315 35 17's but i just want to be sure this is going to pan out how i hope.
anyone run into fitment issues with this setup or the future setups listed above?
will i be needing to bust out my bfh on the inners and/or roll the lips on the outers?
im sure these questions have been answered before but not sure if anything about my setup changes any of the answer outcome.
thanks for chiming in.
96 z/28
Don't know much about how a 50mm offset fits compared to my 36mm offset in relationship to where it sits compared to the fender. I do know the 555r's run pretty narrow so I don't think you'll have any problems outside of the norm in maybe having to massage the inner fender well.
You might have to break out the hammer and grind the bump stop since you're at stock height. The 50mm offset fits better I think for camaros, I have the deep dish zr1s out back.
Im lowered and the bump stop sits on the inside of the rim so it clears. Im using sumitomos and they run wider than the nittos.
