Flat nitto 555r dr...
Old Jul 14, 2011 | 01:23 PM
z28_n_tx's Avatar
Default Flat nitto 555r dr...
Just noticed one of my tires is flat.. Are this safe to patch back up.. Just asking.. I though I saw some where that it was a bad idea.. I use them on street driving if it maters..
Old Jul 14, 2011 | 01:28 PM
Randal McSandal's Avatar
I don't see why they wouldn't be if they're street tires.
Old Jul 14, 2011 | 01:29 PM
xBrian's Avatar
I had a tire patched about 1k miles ago. No problems. Just depends how big the hole is.
If you're worried about it, have it patched and buy a new tire too. Keep the patched one in case you need it
Old Jul 14, 2011 | 02:04 PM
z28_n_tx's Avatar
I just remember seeing some where that it wasn't safe.. I thought I asked you guys.. Thanks
Old Jul 14, 2011 | 02:08 PM
Jake_the_Snake's Avatar
youre not supposed to patch or plug z rated tires for some reason. also, if the hole is in the sidewall, dont patch it. if it were me, i'd try repairing it, but i wouldnt do very many high speed pulls until its replaced
Old Jul 14, 2011 | 02:40 PM
ElkySS's Avatar
iv had plugs in 555rs. did just fine. a patch should do even better
Old Jul 14, 2011 | 04:33 PM
LS1_Sean's Avatar
On z rated tires putting a patch on causes it to loose its z rating. But you "can" do it
Old Jul 17, 2011 | 03:38 PM
LilJayV10's Avatar
I had a good size nail in one of my new NT05R's with less than 200 miles on it. It's still a radial tire and can be patched as long its not a certain distance from the edge. The tire place I took it too plugged it and patched it.
So far so good.
