11'' ZR1 with 315's
I got these through a really great deal... i test mounted them, but haven't driven the car.. I have to get my hands a grinder to modify the bump stops.
They bolted on with no issues, didn't stick out, nor am i close to the rear fenders or the inner wheel well.. It also helps that i don't drive the car aggressive!
![](https://ls1tech.com/forums/picture.php?albumid=8210&pictureid=76799)
![](https://ls1tech.com/forums/picture.php?albumid=8210&pictureid=76798)
![](https://ls1tech.com/forums/picture.php?albumid=8210&pictureid=76797)
the rear is pretty close to center, i will double check after i drive the car this week.
what do you all think?
1 Post
What cookba said. You can take and drive the car around the block and when you come back, unbolt the rears again to see if everything is where it should be or can give you an idea of what you should do to make em fit without any hitches.
