Help me find some 15" or 16" drag wheels and tires
No interest in grinding brake calipers, using stock length rear, and would like a 275 size tire in the rear (smaller in the front)
Really just want it as light as possible.
Would prefer chrome, but black and silver are fine.
Here is the kicker, I have about 800-1000 bucks to spend, can it be done??
Captain Double Post
someone was selling a bad *** set of bogarts n tires the other day for 1400, was a great deal and im sure it only lasted an hour before they were sold, yeah op with your budget your not going to find a wheel that you wont have to grind, why not grind , i did and my crap has been fine for 2 years. the only thing in your budget is going to be pro stars, you should be able to get a set with good tires under 900 with shipping from someone on tech
Here are a pair in Polk County Fl. Just advertised earlier this week.
https://ls1tech.com/forums/parts-cla...t-radials.html
Captain Double Post
if you did wanna grind and go with pro stars im getting ready to sell mine in a few weeks,15x4 fronts ,15x10 rears, and i will give y athe spacers etc, the rear tires are 28 inch . let me know if ya want pics, not real sure im going to sell them but would love to switch up rims, i have had them for awhile
For just wheels, Jim's Tires just dropped his price on Race Stars ... $699 for 3.75/10's, but they are 15's. No 16's, but you could do a 15/17 combo. I am trying to hold out for a good deal on RT-S's with anodized centers, but there are very few selling used wheels only. I also have no interest in grinding and there are very few "budget" options. Keep in mind that even Race Stars require very, very slight grinding on some fbodies.
I'd stay away from Racestars personally, but I won't get into my reasoning why. Weld RTS wheels are the only true street wheel that are SFI cert'd front and rear and are build for LS1 brakes. The 15x10.275 with 7.5" backspace will run you around 259.99 from Summit, and the front 15x4.075 with 1.5" backspace fronts will run you 225.99 from Summit. So a set of those can be had for under a thousand (972.00) and will be a great street/strip wheel. If you're looking for a drag only wheel that will have no grinding issues, I'd look into Bogarts. They are great wheels as well, and Steve goes out of his way to help members out here.
15x10.08 w/medium mounting pad height 16.24# per wheel
Camaro396 ...I didn't see a 15x10.275 in a 7.5 bs w/medium pad height.
