help!!!
Old Feb 23, 2012 | 12:49 PM
zackyv55146's Avatar
Default help!!!
ok so i know there has been talk about a lot of f body owners trying to put bmw wheels on there car and i know alot of people say they will fit well i found a nice set and the guy that has em said he selling em because they wouldnt mount to the rear now why would that be???
Old Feb 23, 2012 | 02:04 PM
VinR1's Avatar
need more info
wouldnt mount to the rear of his BMW or does the seller have a f-body?
stock or aftermarket wheels?
size? (width and offset most importantly)
Old Feb 23, 2012 | 03:29 PM
Umm owner had a 96 camaro after market 18s the guy that has em says I would either need to get spacers or grind out the center alil to fit he just never did it cause he sold his camaro so there just sitting.offset is a 22 and they are 9.5 width
Old Feb 23, 2012 | 04:07 PM
VinR1's Avatar
Ah, that makes more sense. The rear hub is a hair too big for the wheels - some 80 grit to the hub and/or inside of the wheel is usually enough. Most times, just taking a wire brush and knocking the rust off the hub will work too
Old Feb 23, 2012 | 04:33 PM
Sweet thanks man do u think id need spacers still or should they fit fine after I do the hub
Old Feb 23, 2012 | 09:52 PM
VinR1's Avatar
Nah, should go on nice and snug
Old Feb 27, 2012 | 07:39 PM
and thnx to u guys the end result
Old Feb 27, 2012 | 07:44 PM
babbage1109's Avatar
Looks good. Now drop it an inch or two! Lol
Old Feb 27, 2012 | 08:12 PM
thnx alil on the heavy side tho but ya i want to got a few other things in mind first
