Need help!!??
Old May 6, 2012 | 08:15 AM
Angelovs17's Avatar
Default Need help!!??
I ordered the 17" c6 wheels dip disha and need to know what tire size I would need? Any help is apperciated.
Old May 6, 2012 | 08:28 AM
Angelovs17's Avatar
There 17x9.5
Old May 6, 2012 | 10:48 AM
carlos64030's Avatar
275-40-17 or 285-40-17
Old May 6, 2012 | 11:16 AM
Angelovs17's Avatar
Will they rub I'm new to this or is there no way of knowing until you have them
Old May 6, 2012 | 02:37 PM
Nathan C's Avatar
They won't rub. 275/45/17 is the factory size for the WS6 TA.
Old May 6, 2012 | 04:31 PM
99zee's Avatar
275/40/17 is the stock size
Old May 6, 2012 | 10:23 PM
Angelovs17's Avatar
My z28 has 225 50 16 stock
Old May 7, 2012 | 08:17 AM
99zee's Avatar
The Z28 came with 245/50/16
Old May 7, 2012 | 08:47 AM
Angelovs17's Avatar
Well mine must have had diff tire put on it but will the 275/40/17 fit my z28 and will i need my speedo reset
Old May 7, 2012 | 02:18 PM
99zee's Avatar
No adjustment needed. The 275's are the same height as the 245's, 16 vs 17. They will fit perfect. I changed from the 16's to the 17's about 10 years ago.
The 275's are .08% difference in height, which is .1 mph at 60 mph
Old May 8, 2012 | 05:50 PM
rudytirerack's Avatar
LS1Tech Platinum Sponsor
275/40R17 works great. What tire are you planning to go with?
Old May 10, 2012 | 12:58 PM
Angelovs17's Avatar
Not sure probably just go with what I can afford any suggestions
