Cheaping out on tires is putting your life at unnecessary risk
#43
Lots of intentional ignorance going on here (not the OP). Cheap is the wrong word to use though (yes the OP).
I've never seen used bald tires out perform new tires, ever. That, I think, was the point of "cheapening" out. The guy in the linked article bought used bald tires (obviously being three different brands) for his RICEd out ride.
He spent all that money on CAI, Exhaust, rims, what ever else and bought bald used tires. He cheaped out.
I don't think tires have to be expensive to be good. My Continental ExtremeContact DWS's are far cheaper than the Goodyear Eagle F1 Supercar tires I had before them. But the Conti's absolutely destroy the Goodyears in traction in all conditions and directions.
Those $400 Goodyears caused too many situations that could've been an accident; going sideways in 2nd at 15mph in a left hand turn is no fun when you're not expecting it. The $240 Conti's prevented some accidents....
Buying "cheap' good tires isn't cheapening out. But buying $20 used tires is.
I think it's better said, do some research and buy the best tires for your needs regardless of price.
#45
On the flip side I've seen $400 tires get owned by my Conti's....
It's also dependent on the vehicle. $40 tires on a Prius would be fine, but not on a 400+WHP RWD vehicle without traction control.
The point, I think, of the original post is to put good tires on your car. Not cheap used ones like the one in the first post article.
For reference Cheap doesn't always mean low cost, it can also mean low quality or performance, thus low cost. But not everything low in cost is cheap.
Something of great value isn't cheap, but something cheap will have low cost.....
You seem to be more stuck on the word used than the content of the message. Cheap in this instance means;
cheap
CHēp/Submit
adjective
inexpensive because of inferior quality.
"cheap, shoddy goods"
synonyms: poor-quality, second-rate, third-rate, substandard, low-grade, inferior, vulgar, shoddy, trashy, tawdry, meretricious, cheapjack, gimcrack, pinchbeck; More
antonyms: high-class
NORTH AMERICANinformal
miserly; stingy.
"she's too cheap to send me a postcard"
synonyms: miserly, stingy, parsimonious, tightfisted, niggardly, chintzy, frugal, penny-pinching, cheeseparing More
antonyms: generous
of little worth because achieved in a discreditable way requiring little effort.
"her moment of cheap triumph"
synonyms: despicable, contemptible, immoral, unscrupulous, unprincipled, unsavory, distasteful, vulgar, ignoble, shameful More
antonyms: admirable
#47
Only if you drive your car with those tires in the winter, but they aren't all seasons anyway....
Nexen N3000 Owners, Your Thoughts?
Overall though, I've read mixed reviews on those tires. Great traction dry and warm as reported by seemingly everyone. Horrible traction cold though. Good traction wet. Some report balancing and steering walk problems too.
JMHO....
JMHO....
#48
I'm with you hrcslam, but based off the every first post several years ago, "If you cant afford TOP quality tires? Dont build a fast car then." the Op put a value to a TOP quality tire... I'm just wondering at what value does a not cheap, top quality tire even starts at? I'm fully understanding to the nature others have posted regarding worn tires and tires per ones driving style injunction with picking the proper tire but my question still stands.
#49
#50
JMHO....
JMHO....
They seem to be pretty good for what I'm doing but then hey anything would be better than the bald, egg-shaped Dunlops it had prior
#51
Basically I buy tires on the philosophy that I wouldn't wear golf cleats to play Basketball or slippers to play tennis. The best tire I can get for my needs, followed by the lowest price that fits that category.
I did check out those Nexans too ( I believe they are owned by Michelin), but Tucson gets cold and I drive my car year round. Ended up with the Continental ExtremeContact DWS's which had the highest reviews and the lowest cost for a tire that fit my needs.
#53
There is also a big distinction between unsafe, and not up to expectation. See all the time on here, "My Sumitomos (for example) hook and corner for crap". Of course they don, they were cheap for a reason. I am not saying they are unsafe, but you can not expect them to perform with more expensive tires. If one is ok with that, then fine.
My car is just a weekend fun car. When I take it out, I like to push some corners and enjoy it. Given what I wanted from the car Sumitomo, Nexxen, Federal, Maxxis did not even make the cut. I paid $14x per tire for Nitto NT-05's. Do I feel they are worth the extra $40 per tire over a, a wouldn't run on my lawn tractor, Sumitomo. ABSOLUTELY.
