Clearancing calipers for Prostars?
PS. These heavy ZR1s are history. Ha!
For 15x8 rears, to clearance the rear calipers for running without a spacer takes alot of grinding. Grind until you get sick of it, then grind some more. Then grind some more. Then grind till you never want to see a grinder ever again in your life. Then grind some more. Grind, test fit, repeat till it's clear...
And for 15x10s it's worse!
We designed the Bogart rims to be a direct fitment...very few guys running stock parts may have to touch up a caliper or two...nothing major at all. A hand file can be used for the most part.
Aftermarket brake parts in generally are "beefier" so additional clearancing may be needed...this is due to the calipers floating. (not including drag brakes...those make it easier to fit 15inch rims...not to mention we can design the rims so they have even less mass to them:-))
Dear john,
The RR rims depending on your sizing will vary in weight...this weight difference plays a large part into hp losses...BUT if your wanting them for road course racing...you need more strength.
You need to figure out what your goals will be for the rims...to give you an idea..a similar sized rear RR rim will be ~17-18 lbs(generous number)...this is obviously lighter then your current rear. Is there going to be gains...well yes..but if your wanting the gains for drag racing, then obviously, the drag rims are you best choice by far...to give you a number off the top of my head...you could see .1 seconds more with a drag setup over the RR setup. You will also see better traction less rotating weight resulting in better times.
Weight alone is not the only factor...the smaller the diameter, the closer the mass is to the center of rotation, there will be a lower rotational loss. Not to mention when the rim is smaller, the tire (maintaining similar overall diameters) has additional sidewall flex to "bite" the ground.
Once again though, you need to look at what your sole purpose of the rims will be...this really is the determining factor of rim choices.
I can make up a variety of P1 bolted designs (over the welded P1s) not listed on our page if someone is interested in a little different look...
If anyone additional questions, feel free to e-mail me directly at sjmmanufacturing@verizon.net.
Steve
President
SJM Mfg, Inc.
When I spec a set of rims to drag caliper specs, they fit easily...they end up being VERY light...you'll have a bunch of more choices. We can make a front runner ~7 lbs for example:-).
If you can afford it, or don't mind running them, drag brakes are always the best choice:-). I mention it to guys all the time whom are considering drag brakes in the near future and want to purchase Bogarts...we can make them lighter and save a few bucks for the customer in the end. Of course, they would only work with drag brakes though.
Steve
Steve
