Any trouble running this spacer?
Old Oct 16, 2012 | 05:49 PM
TImmy_Jones's Avatar
Default Any trouble running this spacer?
Wanna run this type of spacer on the rear for a set of OEM 04 z06 wheels.
http://www.summitracing.com/parts/TRD-4082/
Any issues? Would a 1/8" be safer? Car is bone stock. Want the wheels to be similar to stock offset. Can anyone recommend a set of lugs to go with it for some better grabbing.
Old Oct 16, 2012 | 06:23 PM
They are the OEM 295 Goodyear tires.
Old Oct 16, 2012 | 10:06 PM
silverWS.6's Avatar
I wanna do the same thing to my rear wheels, I want them to stick out a little bit more and i don't think that would be a big change to have to change lugs. Subbing for experienced opinions!
Old Oct 16, 2012 | 10:08 PM
Donohue96M6Z28's Avatar
I would personally only use adapter style spacers.
Old Oct 16, 2012 | 10:58 PM
02TransAm/Batmobile's Avatar
My recommendation is to upgrade the stock studs to the longer and stronger ARP studs. There are 1.5" and 2.5" ARP studs - even the 1.5" is longer than stock. This way you can run thicker spacers safely. I think it's even cheaper than adapter spacers too.
Old Oct 17, 2012 | 10:49 AM
85Iroc's Avatar
I didn't have any luck trying to run a 1/4" spacer with C5 replicas and stock studs. Wasn't at all comfortable with how short the studs were. I would either buy new studs or use adapter type spacers. Maybe 1/8" would be better but I don't think I would be comfortable even then.
Old Oct 17, 2012 | 05:45 PM
Best post in here...thank you!
Old Oct 17, 2012 | 06:10 PM
The_Bishop's Avatar
Consider a hub-centric spacer if you can, too. Spacers and drive wheels can be problematic, sometimes.
