TSW Nurburgring
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
okay so I sold my C6 17X9.5 and 18X10.5 wheels cause I didn't like them....
I'm looking at TSW Nurburgring in 18X9 with a 50+ off set in the front and 18X10.5 with a 63+ offset in the back...will these fit my car?
stock suspension.
stock suspension.
Alright thanks, so maybe .50" spacer in the front and maybe .75 or 1" in rear...if I put a 1" spacer in the rear will I need longer studs?
They look pretty good on the wheel visualizer. I hope they look that good in person. Gonna shop around for the best price. $300/ wheel is a bit pricey
I've decided to go with C6Z06 black 17X9.5F/ 18X9.5R with General G-Max AS-03 for winter driving and C6ZR1 Gunmetal 17X8.5/ 18X9.5 with BFGOODRICH G-Force Rival
all tires will be
255/50/17F
275/35/18R
total cost is roughly $2700
so its about the same price as the TSW Nurburgring 18X9 and 18X10.5 with decent tires and 1" billet spacers.
all tires will be
255/50/17F
275/35/18R
Agreed. Have something that sets your car apart from everyone else's. TSW > C6Z's. Look for anything between 38-45mm offsets and then they wont look like inny belly buttons lol
Not to mention dropping $2700 on a OEM looking wheel. FYI Ima take a guess you were looking under C5 sizes. You'll probably have to look at the BMW 3/5 series to get the correct offset front and back.
Looking through the options if you want 10.5 rear rim. C5 rear 18x10.5 +63mm with a 20-25mm spacer in the back with E36/E46 18x9.5 +40mm for the front. Or all the way around if you wish to rotate.
okay I was looking around and they don't make the Nurburgring with a 5X120.7 bolt pattern with the proper off set... I did find a set with a 5X114 with 27+ off set in the front and +40 rear. If I got a 1" spacer with a 5X4.75 - 5X114 conversion would that work?
A 5x120mm rim will fit on the 5x120.7mm wheel stud. It is roughly .3mm off on each stud and WILL fit. It's the same pattern as the GTO/G8/Corvette and most BMW's.
http://www.modbargains.com/TSW-Nurburgring-Wheels.htm
I would personally not go below a 40mm off-set because at that point they start sticking out of the fender, ie 35mm. You can do 18x9.5 or 19x9.5.
I know im a few months behind on this post, i have been looking for a few months also at the tsw nurb wheels. I currently run the oe wheels the c6 zo6 replicas 18x9 and the 19x10 i think it is on back.
Reason is wanting to go with the 18 inch drag radial mickey that is 28 inch tall and this rear wheel should work.
I have been looking to go with tsw 18x10.5 in the back with just 18x9 up front.
Just wanting to clarify for myself if i go with the 120.65 rear wheel with the 65 offset ill need spacers? I run them on my current one just to get the even look so the wheel doesn't look sucked in.
For the front if I use the 18x9.5 120 with 40 offset that should work im hoping also.
Any info would be greatly appreciated guys, thanks.
